Electric Power Washer Recommendation?
   / Electric Power Washer Recommendation? #1
cold1313
Gold Member
Northern, Ohio
Kubota M4D-071 Kubota F3990
I'm in the market for an electric power washer come Spring time.
Lots of options but I was wondering if anyone on here has recommendations based on their own experience. I'm tired of reading "reviews" after someone just tried out their brand new power washer for 30 minutes :laughing:
   / Electric Power Washer Recommendation? #2
Think ours is called Black Cat, or something like that. Works good, but the chamber to put soap, etc. in never has been sucked out.
Ralph
   / Electric Power Washer Recommendation? #3
I have two large pressure washers, but they are pricey units (one is a 13HP Honda powered CAT pump, and the other an older electric Hotsy).
I also have a little consumer "Sun Joe", which for a cheapie unit, seems to be holding up....so far.
   / Electric Power Washer Recommendation? #4
Ralph
Did you put the "dribbler" nozzle on it? :rolleyes: They typically won't siphon from that tank with a high pressure nozzle.
I bought one of the $100 electrics off Amazon last summer. I've used it a lot during my Ford 3910 restoration. It's still working. I have two other gas powered but they both bit the dust a few years ago. Be sure to drain them after each use. And keep the connections clean of debris.
   / Electric Power Washer Recommendation? #5
I’ve got a 120v Karcher that works well for what it is, but it will never compete with a 5gpm gas powered unit. It’s at least 20 years old, so I’ve got no complaints on durability
   / Electric Power Washer Recommendation? #7
I bought a small 2200 PSI one from Home Depot or Lower..dont remember,,But its green in color and Its ok...I use it to clean dirt bikes after a ride. It struggles to really clean all the dirt off and will not do a very good job cleaning vehicles..It always leaves a thin film of dirt still on the paint
   / Electric Power Washer Recommendation? #8
That is pretty much the situation with all similar low pressure COLD water washers!
   / Electric Power Washer Recommendation? #9
https://www.lowes.com/pd/Greenworks-Pro-Greenworks-Gen2-2300-Pressure-Washer/1003196492
I got this one a couple years ago. We needed to powerwash the fence in front of the house. Some contractor wanted $250 to do it. It took me 4 or 5 hours to do it with this unit. It worked well for that purpose. It also does a good job cleaning off horse blankets (take them off horse first!) and the tractor and implements.
Pros to the electric are you do not have another engine to maintain.
Cons are not nearly as much power as a gas unit and you have to power the thing if you are far from an electrical source. I use my stand by generator for this purpose.
I also powerwashed the deck before staining it. Worked well for that purpose too. Blew all the loose stain off and left me a nice clean surface to apply new stain to. That was just this late summer so no word on how the stain is holding up yet.
I think the biggest thing is to understand what you are buying and its power (or lack of power) and the jobs it can realistically handle. If I was needing to regularly powerwash large farm equipment this machine would not be up to that kind of task. For my 24 horse power SCUT no issues.
   / Electric Power Washer Recommendation? #10
I found that as long as the electric power washer was stored inside and didn't freeze, they would last a while.
I have a Sun Joe type, going on 4 years and still works fine for clearing grunge off cement and the house.
Also less dangerous for the wife to use vs. gas powered.
   / Electric Power Washer Recommendation? #11
   / Electric Power Washer Recommendation? #13
Have the Sun Joe here also (actually have 2 of them).
   / Electric Power Washer Recommendation? #14
I'd get a new Stihl!
   / Electric Power Washer Recommendation? #15
You couldn't give me a gas unit. Mostly for the noise. I just have a Marathon Motor and a CAT pump on a cart. Not a piece of plastic on the thing. Had it twenty five years or so and I bought it used. It is 120 Volt, can't be switched to 240 and I regret that, because 15 amps isn't quite enough and it will blow certain circuits. But at 240 you would also be limited.
   / Electric Power Washer Recommendation? #16
Bought a Craftsman 1600 psi from Menards for $99 three years ago when my old campbell-housfeld died and couldn't get parts. It's super light and easy to carry and perfect for light duty cleaning like lawnmower, siding, decks. $99 is still their advertised price for it. If I was still haying and needed something more powerful I would still use this one for cleaning most stuff as it's easy to carry around.
   / Electric Power Washer Recommendation? #17
I have a 3200PSI model - Husky. It will strip the paint off your vehicle but it won't take that last uber fine layer of mud off. I just use a long handle scrub brush and hot soapy water.
   / Electric Power Washer Recommendation? #18
Hot water is what makes the difference!
My antique 1000psi, electric motor, fuel oil fired Hotsy, does a better cleaning job than my 13Hp Honda powered 4500 psi cold water CAT pump unit.
   / Electric Power Washer Recommendation? #19
I bought a foam gun/canon. Fun to use. Seems to get my truck clean but wanted to show off to a friend and it left a film on his truck. He basically said, what good is that? He's from the city though! Touchless car washs must have a chemical to address even city film.
   / Electric Power Washer Recommendation? #20
The cheaper 120v electrics may not have the power the gas units do.
But commercial 240v electrics certainly do.
We have a couple commercial electric hot water power washers at work that work dam good.
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A56438)
LMC 2-Row Planter...
2023 Chevrolet Tahoe SUV (A59231)
2023 Chevrolet...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
2005 Mitsubishi Fuso FE84D Auto Crane 3203 PRX 3,200 LB Crane Utility Truck (A59230)
2005 Mitsubishi...
