Fruit tree blown flat
/ Fruit tree blown flat #1
ponytug
Super Member
Bay Area, CA
Power Trac PT1445
Hey folks,
We had a major windstorm recently that blew one of our 15' fruit trees over. The trunk is still ok, but the tree is basically on the ground.
Anyone have advice on how to pull the tree to vertical and how best to stake it once it is there? I was thinking of running a pull rope over an 8x8" post to get lift out of a horizontal pull and then using 3-4' pipes driven in the ground as stakes.
Thanks in advance.
All the best,
Peter
/ Fruit tree blown flat #2
Those kind of jobs demand using what you have and your post should work. You didn't mention varity but most fruit trees are grafted so keep that in mind when pruning. Lots of roots were damaged or lost so I would prune top heavier than past years then nip any buds during growimg season that come out below graft. This is a wag but you probably should irrigate half as often and twice as deep from here on because it sound's like roots were shallow.
It is an avocado, and they are known for shallow roots.
What seems to have happened is that the roots upwind just sheared off underground. I have never seen anything like it. It was the worst windstorm in over a decade.
All the best,
Peter
/ Fruit tree blown flat #4
Another issue with the roots:
I planed 2 oak trees. One was as a seedling and out in the open exposed to the full force of the winds. A few years later, I planted an 8' oak in a 5 gallon pot. Roots were obviously pot bound and I spread them out the best I could. Many years later it had gotten up to 15', the seedling to about 20'. We had a hurricane come thru and take out many trees. The oak seedling did the best, if you looked close you could tell the soil on one side was an inch higher than before the wind. The potted oak was over at 45*. The root system did not fully spread out and the tree was blown over.
/ Fruit tree blown flat #5
I heard that Texas gets a lot of wind but it sounds worse than I imagined. We rarely get winds near that but the gum trees may break a big branch off but they break even with no wind. Hope you can save your tree.
/ Fruit tree blown flat #6
My poor 9 month old Papaya trees were so pretty before the last hurricane hit them a couple of months ago. They had most of the branches blown off and were leaning at 45 degrees. I'm hoping that they can make it through the rest of the winter and recover in spring.
When we had papayas, not here, they always seem pretty resilient to wind, even though the trunks are pathetically weak. They seem to just lose leaves (fronds?) and come back. I admit that we did tend to plant them in places sheltered from direct winds.
All the best,
Peter
/ Fruit tree blown flat #8
Wow,it realy did a number on those trees,I hope you can save them. Look's like the :umbrella: made it through unscathed.
/ Fruit tree blown flat #9
I have had that happen twice, both times I ended up cutting them down. I staked one up like you describe for a year or two, got tired of mowing around it, took the supports down and it blew over again. After the third time I gave up. I would say you can save it but plan on leaving the supports up permanently. I used anchor rods, the kind you screw into the ground and larger ratchet straps.
/ Fruit tree blown flat #10
It's a good idea to put down mulch to supress weeds and grass out past anchors. That will save mowing and weedeating under and around plus retain moisture for better growth.
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
500BBL WHEELED...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
Giyi GY-STB47 QA Telescopic Boom (A60463)
Giyi GY-STB47 QA...
