May get a new chipper
/ May get a new chipper
One step was putting this rounded surround over the input chute. It required use of a pipe clamp across the center to get the side tabs of the gizmo over the outside of the chute.
Here's the picture of the surround in question.
Ralph
Got it dirty this afternoon after spending the morning cutting PTO shaft, lubing and setting bed plate.
New PTO was more of a bugger to get onto the chipper and then onto the tractor. That's the way they are. This one has the push buttons like the Mac's was. The tractor end has a shear bolt. Came with 2 spares.
Set it at mid speed on the hydraulic feed. That was about right. Easy to fix feeding problems by going to neutral or reversing. Just like the Mac, you have to get used to what will feed and what won't. Lots lower operator effort, and I don't need the face shield. There's a plastic sheath and the hydraulic roller covers in the input chute anyway.
Cut the PTO as directed, but it seems to bind some when fully raised and running. Not hitting the QH. Not sure what is going on. I'll just shut it off when raised or only raise it a little bit to go to the next pile.
This one is a lot more weight and distance back there than the Mac, probably near 400 # heavier and 3 ft or so longer. Would not want the bigger WC68 with its 710 #.
Here it is a bit dirtier.
Ralph
/ May get a new chipper #63
I was looking at the WC68.
So how did it do? I have lots of limbs about 6-8" to shread. Let me know how it does.
It's like any chipper. You have to learn it limits. It does up to 4 inch but does bigger if the side branches either break off in the decreasing size chute or are crushed by chute or hydraulic roller. (Like some decayed stuff I used to throw into the big chute on the Mac because I knew from its weight that it would shred, not chip).
Easy to throw into neutral or reverse or forward on the hydraulic roller, completely seamless in its operation. The discharge chute can be rotated about 270 degrees and not interfere with the folded (never put up) ROPS. Easy to come back around and to scoop up the chips with the FEL if you want to save them.
I've the roller speed set at about mid point, which is good for me. Others faster on their feet and without lower leg neuropathy might be able to run it at higher speed. Think my 2025R would take it full speed at about 2500-2700 rpm vs. about 3000 being the "540 PTO" speed. Just don't need all that hp. Think my old 4010 at 18.5 hp on the engine would run this one fine.
The WC68 would be too much weight on the back for the 2025R, but it would handle chipping fine probably at 3000 rpm. Hp is proportional to the square root of the diameter of wood being chipped.
Ralph
Here's the buyer's JD 3 series with our old Mac on it. Told him he needs to buy some pins to convert the Mac to Cat. 1 to continue to use his QH on it. It's Cat. 0.
Ralph
They left out when to add the hydraulic oil in the Operator's Manual. They need to add some verbal like, "The reservoir capacity is 4.5 gallons when operating on flat ground. However, if operating the tractor down slope from the chipper of if the chipper is sloping left, it would be better to only add 3.5-4 gallons to the reservoir." Today, I was operating down slope and slightly left slope, and a small stream of oil was coming from the reservoir cap.
Ralph
/ May get a new chipper #68
IIRC the OE manual recommends operating the unit on level ground. I don't think it means absolute level. When I have been on slopes i have used scrap lumber to level the unit...even though the tractor itself may not be level. Correct me if I'm wrong.
\Cheers,
Mike
\Cheers,
Mike
We've a 100 foot drop down the hill behind the house to the creek over about 4 or 500 ft. Cannot level the unit with pieces of lumber. Impossible. Gonna syphon off another half gallon to save the oil this morning.
Ralph
/ May get a new chipper #70
Ralph
Can you put a rubber hose extension on the fill to stop it from leaking out?...
/ May get a new chipper #71
Ralph
I think you'll be fine with less oil however if your chipping for long periods, feel the hoses for excessive heat.
/ May get a new chipper #72
Ralph
I think the manual said the shear bolt should on the chipper side of the PTO shaft
That's where I put it.
Think the "binding" noise I heard when raising the chipper with it running is some small pieces of wood sliding forward enough to contact the roller and then being chipped.
Ralph
Particularly in the winter. Figure that's what the 4.5 gallons is for: cooling in hot weather. Think less of a problem with the ISO 46 oil, too.
/ May get a new chipper #75
Here is a totally off the wall comment..... You can make the steel shipping pallet cage into a manlift cage.....that is what I did with my woodmaxx shipping crate.
/ May get a new chipper #76
I had no interest in shopping for a wood chipper, but after reading this thread and watching YouTube videos all afternoon,
I WANT A WOODLAND MILLS WC-68 REAL BAD!
I better quit thinking about it! :eek:
Well..... Good news, my wife thinks we need a Woodland Mills WC-68 so I ordered one today! :) :cool2:
/ May get a new chipper #77
Maybe your wife could talk to mine.
/ May get a new chipper #78
I just asked my wife and got a big NO..............:laughing:
The wife claimed the top for a table, and I have 4 castors good for 175# each to put on the bottom part as a dolly.
Ralph
/ May get a new chipper #80
Ralph
Please keep us updated on that........I will need to do that also!
Now I need to sell my old Bearcat 70554 Chipper/Shredder!
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Peterbilt 567...
JLG 460SJ TELESCOPIC BOOM LIFT (A62129)
JLG 460SJ...
(APPROX. 100) UNUSED SDLANCH 6' CORRUGATED STEEL (A62131)
(APPROX. 100)...
PALLET OF SITE FENCE STABILIZERS (A62131)
PALLET OF SITE...
2003 Ford F-250 Pickup Truck (A61568)
2003 Ford F-250...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A61166)
New/Unused...
