220V Plused spray MIG welders?
/ 220V Plused spray MIG welders? #1
MinnesotaEric
Super Member
Nevis, MN
Kioti NX6010
I picked up a 4 into 1 bucket last year that I need to redo the configuration of the pins so I can attach it to my Pay Loader. I figured this would be a good opportunity to step into a dedicated 220V multiprocess welder. Among other things, I'm interested in the pulsed spray process so that I can transfer on vertical angles. I looked into Miller's impressive 255 but am still reeling from sticker shock. Does anybody happen to know of something comparable? I don't need the 60% duty cycle and am open to suggestions and advice.
Thanks!
/ 220V Plused spray MIG welders? #2
What is the sticker price??
/ 220V Plused spray MIG welders? #3
doesn't everlast make one?
/ 220V Plused spray MIG welders? #4
You needto weld a few ton of steel a week to justify costs of what you pick up using pulsed Mig.
Big worldwide company in Peoria been learning a lot bout how NOT GOOD pulsed is lately.
/ 220V Plused spray MIG welders? #5
Pulsed Mig is a pretty vague term. Many variables in this category including Twin Pulse which can be set up exactly like an AC/DC Tig welder only it uses Mig process. Twin Pulse is much better out of position than regular Pulse mode. You can go as basic as a Miller 350P or Lincoln 350MP but there is a much bigger world out there as it relates to Pulsed Mig.
Rather than stick welding, I'd like to spray transfer using the MIG process for better penetration (MIG-wise) but spray transfer is subject to gravity. I've never used a pulse welder, but as I understand it, pulsing allows the spray transfer to be used in vertical applications as well as offering less splatter and a little better penetration.
Big Barn, the base model Miller 255 (which is all I need since my have the extra stuff with my Miller Multimatic 200) is around $2800.
(removed), I expense this kind of thing out on my taxes which lessens the pain of purchasing to a degree, but yes, you're right: this one is more than I want to spend since I'm saving for a shop.
LittleBill21, I haven't looked into Everlast; would you happen to know if they have something comparable to Miller's 255?
/ 220V Plused spray MIG welders? #7
For your application here you may want to consider Dual shield 71T-1 wire instead of a basic pulse mig. Lays a beautiful out of position bead and is likely what the buckets were welded with. 71T-1 is in many ways the wire equivalent. to 7018. Check it out. Of course you will still need a 230v welder or engine drive with feeder.
Thank you for the tip on the wire. I'll look into it right now as I just got off of the phone with Everlast. Everlast suggested their MT 275S.
/ 220V Plused spray MIG welders? #9
There are a few nice welders not that far from you. nice Hobart Beta Mig 251 in Forest Lake for $1000. I have friends at Bemidji Welding Supply I could check with to see what they have as well. All you need is 26-28 volts to run 71T-1 wire. Good luck on your project..
/ 220V Plused spray MIG welders? #10
Everlast MTS 251 Si, a MIG-TIG-Stick welder. Price is ~$1600 and the model goes on sale often for less. It will spray weld and I wanted that capability. (The cat's meow with .045" wire and CO2)
Pulse is good for TIG too. 'Synergic' MIG keeps a steadier arc when welding OOP and holding the torch is awkward. Mine came with full TIG pkg, torch, foot pedal, etc.
Note that while a versatile welder, the included MIG & TIG torches are 300a class and rather husky. I added smaller '200a' ones for working in the mid 100s amperage. Kits are available cheap to convert other bits to 'Euro-Quick' attachment.
I suggest to download & read the manual for any welder before popping wallet leather. I don't need every feature included, or the full capacity, but then my car has four doors and a CD player that I don't use.
btw, at 70 I decided against med school and plan to just take a welding class or three. I'm much better with steel than with bloody flesh anyway. :D
2015 Komatsu HM400-3 Articulated Dump Truck (A60352)
2015 Komatsu...
2017 Komatsu PC138USLC (A60462)
2017 Komatsu...
FORD 6610 TRACTOR (A59823)
FORD 6610 TRACTOR...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
CASE TV450B SKID STEER (A62129)
CASE TV450B SKID...
