New House Build in WV
   / New House Build in WV #272
Your guy may do this but I'll just mention it anyway because it was this time of the year for me as well and I (and my carpenter and drywall guys really appreciated it). When they came to run the ductwork they brought a basic electric furnace and and just set it in the middle of my house so we had clean heat instead of the propane or kerosene heaters we were planning on using which emit moisture. As they did the ductwork they covered each register hole with scraps of plywood. They then left the electric furnace and told me to call after the drywall was primed and they'd return and install the heat pump and air handler and pick up the electric furnace.
My electrician had some electric baseboard heaters we wired up to heat the house for a month or so until the hot water boiler system was installed. Not cheap on the electric bill, but it was livable in the basement and the upper main floor was warm enough to work in.
Also, not remembering if you need inspections, but my electrical and plumbing had to have the rough inspected before insulating the walls. I am enjoying your build. Jon
Drywall prices in your are are quoted by "board foot"?
That’s what I’ve always heard the drywall contractors talk about. They base it on a 4x12 sheet. 4x12=48x.65=31.20 per board times number of board used. Quote is based on estimated number and final bill is based on the actual used, of different. The per foot amount is based on the difficulty of the house.
Not sure all do it that way, or if any still do, but the couple I know use to do it that way, I just assumed it was the standard way of doing it.
Trying to use natural gas as much as possible since it costs me very little. I’ll see what the drywall contractor recommends. Unvented stoves are easiest to use temporarily, but they also create moisture in the air, not sure if it’s enough to matter or not. I know when we built my in laws house, diesel bullet heaters were used during drywall.
No inspections here, fortunately.
Glad your enjoying the build, I’ll try to get some pictures of my electrical work tomorrow to post.
   / New House Build in WV #275
That痴 what I致e always heard the drywall contractors talk about. They base it on a 4x12 sheet. 4x12=48x.65=31.20 per board times number of board used. Quote is based on estimated number and final bill is based on the actual used, of different. The per foot amount is based on the difficulty of the house.
Post #269 by TnWV references drywall pricing by ""board feet".
That is the method commonly used only for lumber measurement.
I am only familiar with drywall pricing by the surface area,.... SQUARE FEET!
Sorry for the confusion, square feet is what I meant.
I’ve lacked in posts lately, it’s just been super busy. We have worked non stop, but it’s seems like we never get enough done.
Electrical is about 90% done, just working out some lighting. We want plenty of lighting in the vaulted ceilings but I’m having trouble with layout and figuring how much is enough vs. too much and what to switch together vs. separate. This is especially true in the kitchen, I’ve never wired a house with vaulted ceilings in the kitchen and I’m having trouble deciding what will work best.
Half the house plumbing drains are complete. We had a nice day today, so I took the afternoon off and cut the plumbing vents through the roof. The metal roof made it challenging. 8/12 is steep for metal, and staying on it, even with ropes, is difficult. I guess I need a full harness to make using both hands easier. Got both vents installed and hooked the one side up to the finish plumbing drains.
HVAC is finished until I get the pad poured for the outside unit. Nice to check that off the list.
A few pics of the work.
I was planning on installing the septic myself, as I’ve done multiple times before, but decided I don’t have the time and hired it out. They showed up unexpectedly about 3:30 today and within an hour or so had the hole dug, tank set, hooked up to the sewer line coming out of the house, and buried. Those guys don’t mess around, it was their second system of the day, taking advantage of the nice January weather. They will complete the install of the aerator and drain field tomorrow.
   / New House Build in WV #278
What is the size of that tank?
Looks kinda small in the pictures.
1200 gallons. It’s two Pieces, bottom half is already in the hole. Looks pretty big in person. There will be another tank that houses the aerator, not sure on its size, and 900 sq. ft. of leach field. Unfortunately, it’ll all be buried before I get home to take pictures.
   / New House Build in WV #280
Try to get someone to take pictures for you!
Pictures can be VERY helpful if you should have future septic problems.
1200 gallons should be good for up to, and including, 4 bedrooms.
No garbage disposal....EVER !!!
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A55302)
2022 New Holland...
FORD SUPER DUTY TAILGATE (A51406)
FORD SUPER DUTY...
Allmand Light Tower (Runs and Works) (A50775)
Allmand Light...
(INOP) FORD 7710 TRACTOR (A51247)
(INOP) FORD 7710...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
