L3430 block heater
/ L3430 block heater #1
jeffgreef
Plumas County, California
Farmall, Gibson, Windolph, Simar, Bear Cat, Vaughan, Howard
Help me out, Kubota gurus;
Bought a block heater for my 2003 L3430 GST, but I guess I got the wrong one. Part I got is 70000-73595. It is the type that pushes in with O ring seal. Instructions say to instal on front of cyl. head, but not possible because water pump is in the way. I knocked out the middle freeze plug on the block, no room for the heater element to fit inside.
So- what do I need- one of the type that threads into a sleeve, which itself is a push fit into the freeze block hole? Other possibilities? Got a part number?
Thanks- Jeff G
/ L3430 block heater #4
Watch out. The water jacket might be an issue. A few years ago someone drilled too far and had a huge problem. Just saying.
Wow! Did they drill thru the freeze plug and then thru the jacket? Slight error in judgement!
/ L3430 block heater #6
Drilled through the cylinder and piston. It was a nice detailed read and for sure a lot of pain for the owner to get it back running. That's why you find those warnings on block heater questions.
3Pt Tree Spade (A66285)
3Pt Tree Spade...
2001 WORKHORSE CONVERTED TO FOOD TRUCK (A59914)
2001 WORKHORSE...
VICON ROTOFLOW SPREADER (A63291)
VICON ROTOFLOW...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
2016 Ford Escape SUV (A64557)
2016 Ford Escape...
