IBC Totes
/ IBC Totes #41
In my circumstance I liked the halved tote idea for two reasons. The first, mainly the capacity of our little tractor. The second is that I had made our back deck so that I can set a half pallet up there comfortably to fill the wood box. Seeing as though we most years don't go through a cord of wood, it should work for us. I went to the 25$ a tote guy a couple years back and strapped six in the 5x10 trailer thinking that that I could easily sell some if I didn't use them. Four of the six I see have the full metal bottom and unbolt from the base. No bladders with mine. I've added enough soil behind the shop over the last few years to either build a loafing shed or buy one from the carport people for the riders, tractor implements and firewood. The bladder roof is a great idea though.
We did aquaponics awhile back and used a submerged IBC for a fish tank. Fortunately there was a guy who used his old building in the warehouse district for barrels, IBCs, etc - all kings of useful and hard to find at the time things. We still have many barrels left. He used to keep the ones clean and labels on so you could see what was in the totes. A good find for not lots of money back then. He's prolly dead and gone. Now there has been another business set up outside of town that somewhat caters to the preppers and such. I see that they get a 199$, since a know ya price out of the IBCs w/ tanks.
/ IBC Totes #44
Isn't a tote ~ 1/3 of a cord- depending on stacking? IBCs are about 40 x 48. A cord is 48 x48x 96 Here is chart which is handy so you can see what wood species tend to weigh green vs dry. Wood Heating | Forestry | USU
/ IBC Totes #45
The volume is around .36 of a cord depending on how you stack the wood in it. The corners are rounded but your splits can stick out a little. I usually stack a few inches above the top because the wood shrinks as it dries.
/ IBC Totes #46
Totes come in different sizes. I usually see them listed as 250, 275, 300, or 330 gallons.
/ IBC Totes #47
I'm talking about the common 275 gallon size.
BTW it looks like the new thing in IBC totes are collapsible models which are cost-effective to return ship. If those take over the supply of the comparatively cheap used cage-and-bladder types will be reduced.
/ IBC Totes #48
I always figured I couldn’t use totes for firewood. My tractor might pick up 800 lbs and get it up to the house. I could always fill them part way I guess.
/ IBC Totes #49
The totes in my earlier post hold just under 1/2 cord of wood. My tractor has 2700 lb lift capacity. It is enough. The heaviest wood I burn is oak.
The smaller tractors cannot handle much wood.
Without an access opening, getting wood out of a tote will be a PITA. Do a test of whatever you decide to use before loading a bunch up.
/ IBC Totes #50
Here is how I do firewood:
Less plastic to dump, more capacity and provides weather protection.
View attachment 682465View attachment 682464View attachment 682466
Hello Shooterdon - Very impressed with the way you cut the bladders as shown in your picture #3. Since a tote that is filled with wood that is level to the top holds 3/8 of a cord - I estimate that I could hold 5/8 of a cord in each tote if I cut bladders in same manner as you. I am currently storing my wood in 20 totes and therefore could store an extra 5 cords in the same amount of space. Thanks very much for a great idea.
/ IBC Totes #51
Anybody know what a tote full of firewood ways? Say filled to the top or slightly less.
Mine hold 1/3 cord and I estimate mine weigh 1300 lbs with fresh cut oak and maple which weighs about 4000 lbs a cord. When it dries it is a bit lighter. I notice the difference when I move them for the first time vs bringing them back to the house right before winter.
/ IBC Totes #52
Thanks!
It takes about 45-60 minutes to modify one. Mine hold just under 1/2 cord. I have 32 totes...one just a cage. That gives me over two years of firewood. I used zip ties to attach the plastic bin. I am 70 so needed to find an easy way and cheap way. I doubt I will ever need more in my lifetime. I have $800 invested.
/ IBC Totes #54
Wow, got to save that craigslist ad for posterity:
/ IBC Totes #55
^ that boat is hillarious. Might be a bit tippy.
I figured I would snap a pic of my tote coverage for winter. Keeps the wood nice and dry, and pretty easy to deal with for quick on/off and tote swapping. Just two old cruddy sheets of plywood standing vertically in the middle of the stack, and the leftover tarp roof from a $99 carport. And tarp would do.
/ IBC Totes #56
I need to start looking for these, again... Like others have posted, prices seem to be all over the map. I stopped to look at some, coming back from deer hunting this fall. He wanted $125 each. :laughing:
/ IBC Totes #57
It seems like when they need the space, $$ comes down.
/ IBC Totes #58
I've been grabbing them from work when available, e leakers gets set out and they have to pay to dispose of them. Often have oil in them, normally less than a couple gallons, which I collect and dispose of properly. I cut the top off and put it back on, including the removable top ribs, and tack the sides with a few self drilling screws. Sawzall takes out a section of tubing to make side access, and forks on the tractor make them easy to move. I had about a dozen filled with firewood last fall, down to 3 now... we keep the house warm!
But the OP was what to do with the removed bladder...
I've done several things... the bottm that's missing the top I used for a firewood tote had collected junk barbed wire when we tore out old fence, cut the bottom off and the flat side panels were cut into 6' long strips and 2 used to make a hot tub cover winter roof, some were used as siding on a chicken coop wall, some used to cover truck parts (axles, transmissions, motors, etc) that were on pallets, covered with upside down bladder to make a roof... I'm gonna cut one up to make a cover for my cement mixer next.
/ IBC Totes #59
The bladder plastic can be heat formed. Play a propane torch over it until it turns clear then put it in the shape you need it and hold it there til it cools. Best to have a form to bend it over, and gloves if you need to touch the hot part.
/ IBC Totes #60
I just picked up a couple for $20.00 each. Now I'm wondering, once I fill them with wood it looks like it is going to be quite difficult to take it out without standing on my head.
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A63689)
2023 Kubota Z412KW...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A63688)
2024 Kubota...
2000 CATERPILLAR 988F SERIES II WHEEL LOADER (A64279)
2000 CATERPILLAR...
Case 950 8 Row Air Planter (A63118)
Case 950 8 Row Air...
2005 BOBCAT 323J EXCAVATOR (A64279)
2005 BOBCAT 323J...
2016 CATERPILLAR 259D SKID STEER (A64279)
2016 CATERPILLAR...
