Smart Shop tips!
/ Smart Shop tips! #342
I know what DOESN'T work is the specialty kits they market to rejuvenate headlight lenses.
Yep!
Mostly they are fine sand paper all the way to 1000 grit.
Auto body rubbing compound will do that job just fine at a fraction of the $$'s.
Heck even tooth paste (very mild compound) will do it also with more elbow grease.
/ Smart Shop tips! #343
Good idea.... I will order today!
I just made it a habit to pull the cable every time I'm in the garage. No more standing on my head to bleed off the moisture (Cable operated tank drain).
/ Smart Shop tips! #344
Yep!
Yup!
3M auto body compound works great!
/ Smart Shop tips! #346
Most probably know this already but if you are needing to find the center of round stock to drill a hole, the quickest way I have found is to use a ruler or something straight on top of the round stock, then place the drill bit on top of the ruler. As the material is moved back and forth, the ruler will rock from side to side accordingly. Once the ruler is straight you are in the center of the material, or at least close enough for most purposes. The same can be done on a lathe to get the cutting bit in center.
View attachment 682151 View attachment 682152 View attachment 682154
I have a tool for that. Chuck up the round part and the V will pivot on the round stock until the two lines are lined up. Won't work in the lathe, but works on mills and drill presses.
/ Smart Shop tips! #350
got a link?
This was handed down to me. I'm sure it was purchased prior to the internet's existence.
Thanks BB.
Yup, I have seen those before. I'm just cheap though, I use what is handy.
I used it for work when I was a toolmaker, so I had to be precise. If I needed to be more precise I'd use an edgefinder on both sides and split the difference. That only works with a mill, though. If I needed it to be within 0.0005" I'd use my indicator, but that's a whole different ballgame than garage work.
/ Smart Shop tips! #351
I'm not a toolmaker or even a machinist but I do the same thing. Within .005 I use a ruler. Within .001 I use an edge finder. Indicator for anything closer which for me is rare.
/ Smart Shop tips! #353
Was a toolmaker? :confused: My job ran out and I retired, but I haven't forgotten much. :p
/ Smart Shop tips! #354
I've moved up in the world. I'm now a design engineer. I was looking at prints that made no sense and thought "I could do better!" It was a nice transition. I get pushback from other engineers because I have no college degree in engineering, but my experience is where I'm miles ahead of them. Now I don't have to work overtime (60 hours a week standing on concrete was tough on my feet). And I come home clean, not smelling like a machine shop. Plus now I have all sorts of connections for anything I need for my at-home engineering projects, and time to actually work on them. And I have access to SolidWorks.
I haven't forgotten anything, I just use the knowledge differently now.
/ Smart Shop tips! #355
Sounds like a fantastic transition!
/ Smart Shop tips! #356
Not sure I'd always say that's moving up in the world as engineers can be a rather odd bunch (speaking as an engineer myself) - but still the pay can be good and the work interesting if irritating at times (usually most irritating when dealing with other engineers who think being an engineer means their education makes them smarter than reality/mother nature/God/etc. :rolleyes: )
If there's one thing that life has taught me: it's that reality is always right and trying to believe/do otherwise is a quick path to a rude awakening and (in extreme cases) personal injury/death. ..and it's one of those lessons that only experience seems to be able to teach.
/ Smart Shop tips! #357
It is sure nice to be off my feet for a change. This is the first full time job I've had that I wasn't on my feet the majority of the time.
Moving up for me meant more time off my feet and with my family, and just a better quality of life. Because of all the overtime I was working as a toolmaker I actually took a pay cut to become an engineer. After doing it for 4 years I'm now back up to my previous salary. I do mostly improvement and new design on machines. It takes certain traits to be a good engineer, being odd is just one of them. I know what you mean about other engineers, mostly the recent college graduates. They don't have "that" experience. I've always been cautious, so reality has never bit me that hard, plus I learn by observing others.
"One may learn by reading, a few may learn by observing others, the rest just have to pee on the electric fence."
/ Smart Shop tips! #358
This is sort of a shop tip, hopefully help someone. Yesterday I went to put on my favorite coat and the zipper broke.
I bet most people throw out and buy new, but a good coat isn't cheap.
At Walmart they sell Coats & Clark made in USA zippers, get the heavy duty coat one.$2.47!!!!!
I use upholstery thread, if you notice I didn't sew perfectly straight but three passes, it's on there. Heavy metal not plastic zipper.
I have two other ones I've I've repair like that over the years, new zipper outlasts the coat.
Fixed for less than three bucks.20210114_145632.jpgView attachment 683186
/ Smart Shop tips! #359
I suggest that your sewing is quite good. :thumbsup:
Many of us struggle to get the thread & bobbin tensions right for the material we sew. :rolleyes:
Proves a guy can do more domestic stuff than just cook dinner.
btw, I've been doing laundry & dishes for 50 yrs. We can do this s__. :)
/ Smart Shop tips! #360
Thanks. You're very kind!
I sew on machine once a year, maybe. I worked next door to an upholstery shop years ago and enjoyed talking with the guys (I was watching though and picking up tips ). I got up nerve and reupholstered a chair we have. To me it wasn't difficult. I'd love to have one of those industrial sewing machines like they had.
There's no masculine or feminine in being able to do things! Now if I could only cook!
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
New/Unused Landhonor 60 Gallon Sand Blasting Cabinet (A65583)
New/Unused...
International 154 Cub Lowboy, Gasoline, 60" Mower  (A62679)
International 154...
2022 CATERPILLAR 313GC EXCAVATOR (A65053)
2022 CATERPILLAR...
New/Unused AGROTK Tire Changer (A65583)
New/Unused AGROTK...
2016 COTTRELL CX09LS2 T/A CAR HAULER TRAILER (A59914)
2016 COTTRELL...
