Should I post shop pics?
/ Should I post shop pics? #1
Sberry
Brethren, MI
Mostly green
You guys would need to pester me as I have a short attn span and dont follow along very well.
/ Should I post shop pics? #3
I triple dog dare you!
/ Should I post shop pics? #5
Should start wid de pics of dat motorcycle thing you went to years back before you became married man. Dey was classic.
/ Should I post shop pics? #6
What's the yagi-type antenna used for?
That was for,,, a,,,, TV.
I got another shack or 2 to keep the stuff I am not working on out of the shop.
/ Should I post shop pics? #9
I'm going to work on hand-held welding before I try it with my feet.
Wow, what a nice shop!
/ Should I post shop pics? #10
My bad-- I thought your building was a new shop.
If that legacy antenna was for TV-- I hope grandpa got a lot of good use out of it. :laughing:
/ Should I post shop pics? #11
Are you the owner of Urka Farms? Looks like a shop that gets used every day!!!!
I am one of the owners, kind of the operator for lack of a better word. I build the buildings. Yes the shop is used every day. Its not very sophisticated, I really rarely use a drill press. I am such a MdGyver and have shortcuts for everything. I had a fire about 25+ years ago and didnt replace some stuff and kind of moved in as needed and really wasnt interested in going down the machine and fab road at the time. I live on rickety rural power and didnt feel like another layer of equipment and its really too far out for walk in biz.
I got a couple 10 welding machines, a torch and chop saw along with the battery tools and couple chests of stuff and another pickup load of stuff or so, real simple. My neighbors have machine although UI rarely need it. Back in the day we were in the potato biz with more moving pieces and job shop built stuff but shopping and parts are so much easier and faster and so much can do from the auto parts store and my scrap pile that I rarely need to machine anything. I stock some stuff, I kind of master it with the same equipment I use forever.
So, the place is really a few tools with a bunch of shelves with stuff I use all the time in the place I use it at, a station or bay system.
Here is the engineering dept.
I am a master of finding just the right thing, straight cut in the chop saw, run 1/2 a rod on it. Its set up somewhat like a pit stop and focuses where our high duty cycle is, hot pressure wash, weld, mechanical, auto/truck/.
A lot was I needed it at the time and the proto worked so well it never got upgraded to those fancy HF carts.
Some of the pics are slightly older and some minor tailoring of carts since. Its extremely ergonomic.
Now,,,,,,,,,,,,,,,,,,,,,,,,, glad to see (removed) still kicking. We go back quite a ways on forums, he steered me to Hobart back in the day.
Ok, had enuf clicking.
My shop tip/project. I need to do one more.
/ Should I post shop pics? #17
I enjoy seeing all your pictures and looking at all the great stuff you have in your shop!!!!
I forget what I posted. This is simple stuff. I do complicated when I have to, if there is easy way I take it.
/ Should I post shop pics? #19
Spend 10 bucks on Anderson plug fer de jumpers. Grill costs lot more.
Reason its that way is for common cables. I ran across the exhaust pipe job the other day The fit was rolled tight when I zipped it with the wire feeder and I didnt get real fussy but it sealed and 15 years later where its all weathered it looks really good. I should have taken a pic, I might if it happens.
I ran across some of these well weathered and they really look great, at first in this highly magnified pic they look crude and they are somewhat. I had found a box of 6010 I forgot I had and they were fingernailing pretty good and I did a lot out of position. Was about .200 wall maybe but hand plasma cut, very crude clean and fit and weld it in single pass to be water tight.
Set of Helicopter Saddle Tanks (A64126)
Set of Helicopter...
John Deere Z994R (A60462)
John Deere Z994R...
Massey Ferguson 250 Tractor (A62613)
Massey Ferguson...
100 gal L Portable Fuel Tank (A66408)
100 gal L Portable...
2020 John Deere 7R 210 (A64126)
2020 John Deere 7R...
Snap-On Zeus Diagnostic Machine (A63689)
Snap-On Zeus...
