Lock that won't freeze
/ Lock that won't freeze #1
BeezFun
Elite Member
IL
Kubota B2710
Need to put a chain/lock on driveway gate. We get ice and snow so I'm looking for some kind of lock that will work in those conditions. I've never seen a key lock that didn't freeze, maybe there's some kind of combination, push button, or something I don't know about that works well in winter. Looking for recommendations.
/ Lock that won't freeze #2
I don’t have that issue but all the farm gates I’ve seen with locks have a bottomless box welded to the gate where the chain passes through. No water in the lock, nothing to free. Doesn’t account for sideways heavy blowing snow but it is a starting point.
Can you describe that a bit more. Does the chain come in each side of the box, drop down through the open bottom, and after you put the lock on, you pull the chain back up into the house to keep it dry?
/ Lock that won't freeze #4
Have you tried rubber coated padlocks that have a cover over the key area like this. waterproof padlock.jpg
/ Lock that won't freeze #5
Our gates have a piece of 4" pipe welded upright, with a piece of flat stock on top. Picture a tin can on steroids, with the open end down. You can weld a metal tab onto the chain for the lock , and cut a hole in the side of the pipe to slide the tab into.
You still might have freezing problems, but you can reduce that by spraying the lock with WD-40 or something better. It's also a good idea to keep a propane torch handy.
A word of caution though... in summertime you may find a hornet's nest in your lock box.
/ Lock that won't freeze #6
I remember that yes, the chains pass through from each side and where the chain overlaps you snap the lock through. Pretty much out of sight. Sorry, I don’t have a pic.
/ Lock that won't freeze #7
Like this, instead have pipe vertical, capped on top.
Slot cut in each side, flat bar or chain connect the two pipes.
With a lock on 1 side.. or both for flat bar.
Other side can be a tab, bolt on flat bar or whatever to keep it from sliding out.
See no reason it can't be adapted for a single swing gate as well.
/ Lock that won't freeze #8
You could use the lock like George2615 posted and put a piece of rubber over it with a couple of wire ties ( rubber roofing work good)......
Have you tried rubber coated padlocks that have a cover over the key area like this.View attachment 680973
Yes I have, the problem I've had is moisture must condense inside when the temperature changes fast, so after a warm day if it gets really cold at night, the next day it's frozen internally even though it hasn't rained or snowed. Also I don't want any more keys, we have people that work for us who have to come in, there's no way they can keep track of another key.
Thanks, that's a good idea. I've trained myself to check for hornets, they're everywhere around here.
I get it. Actually it could just be like a little lean to with sides and a top. A notch in each side to hold the chain ends, then put the lock through the chain.
tnx, that helps
/ Lock that won't freeze #13
There will always be a few days where the padlock will freeze up. I have a propane cigarette lighter in the glove box - just for those days.
/ Lock that won't freeze #15
Here people cover locks with any type of cover that will keep most of the moisture out. Some use a rubber flaps that they just pick up to get to the lock and actuate it. Yearly oiling also helps. Better locks with SS or brass parts helps, but without oil, they freeze just the same. Seems those '"sealed paddle locks" don't work very well keeping water out and they freeze. Let us know what you do!
/ Lock that won't freeze #16
I would think this should be where WD-40 shines. WD originally meant water displacement. True?
/ Lock that won't freeze #17
Silicone lubricant will shed water without attracting dirt.
/ Lock that won't freeze #18
They make an oil for locks which we keep a bottle of. I'm not sure what the differences is but WD-40 is more like a parts cleaner and does not stay around.
I met with the aesthetics committee, she decided unanimously that we won't have any soup cans or rusty pipes on the front gate. I'm going to take an old mailbox that was damaged when a tree fell on it, cut it so it's only about 3" deep and reweld the back onto it. Put a hole in each side with a hole saw for the chain and we can open and close the mailbox door to get access to the lock. Thanks for the ideas.
/ Lock that won't freeze #20
This. I have locks on my trail cameras in the wood around my place. I carry a propane lighter / mini torch and it un-freezes any lock in a few seconds. Easy-peasy.
