If you have Toolcat questions, ask them here...
/ If you have Toolcat questions, ask them here... #661
Not sure how it got bent, just recently bought this machine. The air filter assembly is not secured and that is really the only thing in that area. If I sent it to you will you try to straighten it?
/ If you have Toolcat questions, ask them here... #662
Im in Canada but willingly give it a try if you want me to, send me a pm and I will give you my address
/ If you have Toolcat questions, ask them here... #663
Hello Everyone
My friend Recently acquired a Bobcat Toolcat 5610 SN:A7Y712056 With a SB240 Snowblower SN:713103336.
We are having some issues getting the blower to fire up. When the aux button is pressed and the toggle on the back of the joystick, the engine loads up and goes over relief.
I have tried disconnecting the electrical connector at the aux lines hook up to see if it would turn like a brush hog with no luck. The aux lines aren't even loading up.
The high flow switch does turn on (light up) when the aux button is pressed. From what I have read online this is normal.
There are no codes.
I have checked both fuse boxes at the drivers feet area - I'm not sure if there are more fuse boxes?
All other hydraulics operate normally.
Does anyone have a copy of the auxiliary hydraulic schematic?
Any Input would be great!
Thanks!
/ If you have Toolcat questions, ask them here... #664
I don't have manuals for the D Series, but the Parts catalog shows a diverter valve: Bobcat Genuine Parts Catalog – Official Bobcat Company site
I wonder if that changes flow between rear and front, since you can't use the PTO and Aux at the same time.
I don't know what the indications are if the PTO switch is on when trying to use the Aux Hydraulics.
You might be able to see or feel the hoses get pressure when activated.
I put together a gauge to measure front pressure:
/ If you have Toolcat questions, ask them here... #665
I was kinda wondering about that diverter valve. I had a quick look at it last night.
Anyone ever run into an issue with this valve or the solenoids or switch on them?
Coil Resistance?
/ If you have Toolcat questions, ask them here... #666
No experience with the early models, but I know that the F Series and the G Series would handle that job OK.
For skid steers the ROC (Rated Operating Capacity) is half the tipping weight.
Our F Series maxed out at slightly over 3000 lbs. without tipping or raising the rear wheels:
View attachment 672452 View attachment 672449
They handle the 1800 lb. 7' brush hog just fine and it's weight is farther out than a tote on forks would be:
View attachment 672451 View attachment 672450
I see you have the bush hog!
How would it handle the brush cutters?
Blue Diamond Extreme Duty Brush Cutter Skid Steer Attachment
Would it compare to a JD 333 to 317 size machine?
/ If you have Toolcat questions, ask them here... #668
Hello Everyone
There are no codes.
Thanks!
I spent some more time looking at this toolcat today. I tested the diverter valve solenoid coil resistance and came up with 6.8 Ohms. I also bypassed the harness and directly put power to the solenoid with no change. I could hear solenoid turning on and off when I applied voltage to it - so I believe it is working OK. As for the switch on the diverter valve - I checked it with my meter with no continuity through it. Does anyone know if it is normally open or closed? It is pretty corroded on the outside of it. Does anyone know if this is a pressure switch?
Thanks Fellas, any input would be great!
/ If you have Toolcat questions, ask them here... #669
Hi,
Couple of questions I haven't been able to search out an answer for.
With your toolcats, do you typically see more tire wear on the front or on the rear? I recently purchased a used one, and the tire wear is quite uneven - but not sure if I should rotate or not (don't know if they have already rotated)
Did Bobcat ever produce a newer service manual? My Toolcat is a 2013 - F. It came with a printed service manual - but the service manual was for S/N A00211001 and above - which I believe is from the C era.... I've also found a PDF copy of the same... but nothing newer. Just want to know if they actually did produce an update for the F series. My owners manual is updated for the F series.
/ If you have Toolcat questions, ask them here... #670
My toolcat had 350hrs on it from a school and the turfs have very even wear. I bought a paper service manual online for my G series. Search Toolcat manual on ebay.
/ If you have Toolcat questions, ask them here... #671
What serial number does your say on the front of the service manual? I just found it odd that the one I have is for the older line, want to know if an update actually exists.
/ If you have Toolcat questions, ask them here... #672
It is for S/N B2LH11001 and above Toolcat 5610
/ If you have Toolcat questions, ask them here... #673
Thanks... after knowing they do exist, I kept on the hunt. I eventually found PDF versions of the owners and service manuals for a 2011, which was the start of the F series. Close enough for my 2013.
Looking closer, I think that the previous owner replaced my rear tires, but left the fronts.
/ If you have Toolcat questions, ask them here... #674
Howdy, I have a 2016 “G” Series with approximately 100 hours. the brakes are dragging all the time, at low speed operation it is slightly noticeable, if you go done the road they heat up and you can smell brake odor. There is nothing in the manual about brake adjustment. Any help on this?
/ If you have Toolcat questions, ask them here... #675
Per service manual:
The brakes are located in the front and rear transaxle housings. Springs apply pressure to a stack of disks that prevent the axles from turning when the drive pedal is not pressed. When the travel direction control lever is shifted, the drive controller sends a signal to the pilot valve where a solenoid allows hydraulic pressure to release the brakes allowing the wheels to turn freely.
When the brake pedal is pressed, the drive controller reduces the hydrostatic pump output to zero and drops pressure on the manifold allowing springs to relax engaging the brake disks and stopping the machine. the brake pedal does not directly control the brake, the brake pedal supplies an electrical signal to the controller.
/ If you have Toolcat questions, ask them here... #676
From what I can tell, the dealer can put the machine on jackstands, connect the remote start tool, connect the service PC to the rst, and go through the brake pedal calibration procedure.
/ If you have Toolcat questions, ask them here... #677
Anyone know a source for the side access doors on both the passenger and driver side? Mine were painted over with bedliner by PO, and they essentially destroyed the doors as I had to pry them open. Maybe they are a standard size access door? Anyone know?
/ If you have Toolcat questions, ask them here... #678
Bobcat dealer sell them, couple years ago replaced the 2005 side doors, original were steel with mesh new ones are plastic
/ If you have Toolcat questions, ask them here... #679
PN is 7190171 for the new plastic ones.
/ If you have Toolcat questions, ask them here... #680
I’m in the middle of a big snow plow and the blade stopped going up and down. What can I check?
2020 Ram Promaster City 1500 Cargo Van (A59230)
2020 Ram Promaster...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
Manure spreader for sale
Manure spreader...
2013 Land Rover Range Rover Sport 4X4 SUV (A59231)
2013 Land Rover...
2013 Larson LXI292 29ft. Boat with T/A Loadmaster Boat Trailer (A59231)
2013 Larson LXI292...
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
