Surprised how much block heater helps starting diesel
/ Surprised how much block heater helps starting diesel #81
The thermal shock (rush of ice cold coolant) explanation could makes the most sense, but if it destroys the block heater, then how long after unplugging it should you wait for heater and surrounding coolant to cool? 2 seconds, 10 seconds, 1 min.?
Same thought I had. I unplug my tractor, jump in and start it. Of course, a 250W heater on my little BX and the hood is warm to the touch after an hour in my unheated, but well insulated garage. Guess I won't worry about it. :laughing:
/ Surprised how much block heater helps starting diesel #83
Not if they don't list an amperage or wattage rating. I wouldn't buy one to turn a lamp on without knowing what it is rated for.
Most of the wifi switches on Amazon are rated for 10 amps. I bought some rated for 16 amps, which is fine since my garage is on a 15 amp breaker.
/ Surprised how much block heater helps starting diesel #84
At some point at around 32f I generally use my block heater for 3 hours prior to starting. On my previous L3410 3 hours was the sweet spot where the block didn't get any warmer. With the block heater plugged into a WiFi plug I can either manually turn it on from my phone, or let my pre determined schedule take over (on at 0100h, off at 0400h) so I can head out on my plow run at 4am.
Like others have said, I don't NEED to pre heat in order to start, but the machine sounds happier and I get cab heat much sooner.
Glad you mention the length of time. Some guys here are saying 15 minutes.. I need minimum of 2 hours to get coolant to get warm enough to warm the cylinder walls for a happy start. My neighbor has used a hair dryer down the air intake on his Dozed. Of course the whole engine rattles because it's cold but for a ' I need to get it started now' scenario, it starts.
/ Surprised how much block heater helps starting diesel #85
I forget my actual temperature readings, but I believe 3 hours would raise my block by 40 deg f over ambient in 3 hours. Any longer didn't increase the block temp further.
Re: your hair dryer comment, I have a pull start walk behind mower that is hard starting at 50 degrees or so. I put a small electric heater in front of the intake and it fires right up! I believe my current L4060 has an air intake heater that is computer controlled.
/ Surprised how much block heater helps starting diesel #86
Having a tough February after much warmer than normal winter. We haven’t seen zero since last Thursday, lows have been less than -30°, and the wind has been gale force. My nephew has a Kubota M110GX and has never had a starting problem until now. Impossible to get running so he has had to drag bales out to his beef cows chained to his pickup. He asked if I had any suggestions (yeah, drive it over to my place and store it in my heated shop every night) but that wasn’t practical. So I suggested putting magnetic mount engine oil heaters on the pan (we already have block heaters on everything). My sister said she got a text receipt from the local auto parts store for a magnetic engine oil pan heater this morning and tractor was running this afternoon. I also suggested heating the air inlet with a hair dryer because I read that worked for someone. I thought I told him to make sure he used 5W-40, or 0W-40 if he could find it but I’m not sure if he did. But I can say for sure when a block heater is not enough, add a magnetic oil pan heater. Outfit logging next to me left their skidders, feller-bunchers, and limber-stackers running all weekend so they could be sure to work today.
/ Surprised how much block heater helps starting diesel #87
This week we are to see our lowest temperatures of the winter to this point. It is supposed to get down to 24 degrees at night. You guys dont know what it is like, freaking COLD. :cold: :snowman: :frosty: :cold:
:rotfl:
/ Surprised how much block heater helps starting diesel #88
I have an inline coolant heater that I run for 20 minutes before start and the vehicle pops right off and is ready to work much sooner than a cold start.
The engine only has a 100 hrs on it since overhaul and will start cold but a little heat much reduces the engine wear on start so I routinely use the heater. I have it plugged into a Bluetooth enabled switch so I can activate the heater with the phone.
/ Surprised how much block heater helps starting diesel #89
If the block heater does not work I’d suggest checking to see if it is working or replace with a proper sized one.
/ Surprised how much block heater helps starting diesel #90
Had a Montana 5740C that I put two new frost plug heaters in an for some reason neither one worked, showed continuity but never heated the block. Installed a battery warming blanket and glue-on oil pan heater pad and wired them together on one plug. Between the 5W40 full syn being warm and battery being warm it started like a dream even at -20F
Were the block heaters installed upside down?
2022 John Deere Z930M (A57148)
2022 John Deere...
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
Caterpillar Quick Attach Forks (A60463)
Caterpillar Quick...
Kubota L2502 (A60462)
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2008 HINO 268 4X2 26FT NON CDL BOX TRUCK (A59906)
2008 HINO 268 4X2...
