Welding cast iron
/ Welding cast iron #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
This is a forge blower that I want to fix. It is some kind of a cast iron, never welded it in my life. I was going to use a stick welder but not sure about the rod. Nickel 99? Should I grind it to make space for the weld? I don't have the capacity to heat it up, was planning to weld it cold.
What rod would you use? Any special settings?
/ Welding cast iron #2
If you want that to be a lasting fix......take it to an experienced PROFESSIONAL welder!
/ Welding cast iron #3
about the rod. Nickel 99?...
Nickel 99 worked OK for me on my 1 cast iron repair.
You don't have a kitchen stove, or BBQ or camp stove, camp fire or electric space heater? They all work for pre-heating to various degrees.
/ Welding cast iron #4
If your not going to preheat it, use the back step method of 1" long beads and wait between beads until you can hold your hand on the previous weld. The 99 will work fine.
I don't know what the latest recommendation on peening welds are now. Used to always peen them, then it wasn't recommended.
/ Welding cast iron
Thank you, gents.
Should I just stick it together where it broke? Or grind it to make V weld?
/ Welding cast iron #6
It's going to move around on you when you are welding it. Sometimes it helps to bolt it to hold it close to where it goes. Slight bevel never hurts. If using 99 I like to peen it a little to relieve welding stress. I also like Nickel Silver brazing rod for things like this. Very strong and ductile. If you don't have 99 already you could also use Super 120 or Super Missile Weld 3/32. Good luck on this fun repair.
/ Welding cast iron #7
I would braze a gusset to the flange along with brazing the break. It's a blower so won't see brazing heat in use.
/ Welding cast iron #8
Good idea on the gusset or gussets
/ Welding cast iron #9
WHY???
Brass job at best, Everdur wid single carbon probably better.
(removed)'s Old School, NEVER grind cast, especially s#!t cast like dat. Guy who poured it had no idea what got melted fer dat run, you got none either. Chip or nap light and sand blast to clean up.
Bed it in pan of new kitty litter fer alignment. Better if fixtured to hold alignment. You dealing wid a flange. Gonna want to walk or kinkk, nature of flanges.
Run tackup from inside pipe, verify alignment finish job from outside.. Add couple gussets between bolt holes.
/ Welding cast iron #11
With zero experience, you will almost certainly bugger this up, if you try to do it yourself!
/ Welding cast iron #13
No need for a professional for a simple fix like this.
/ Welding cast iron #14
I totally disagree!
A QUALITY cast iron welding repair is not likely from a novice!
/ Welding cast iron #15
Unless a tractor part I'd rather see you weld it yourself, that way you can post pictures of how you did and may help someone. The cast that gives me the most trouble is stove parts, but this appears separated from high heat so should weld fairly easy, it's just that Nickle rods are very pricy but seem so 1 lb should fix it.
I recommend a little bevel, needs to be shinny anyways, I wouldn't worry about preheat I think post heat/cooling is more important. I suggest 3/32 rods and skip around in 1-2" welds, let cool very slowly when done.......... Nickel 55 ENiFe-CI Cast Iron Stick Electrodes Welding Rods 3/32" 1/8" Nickel 55% | eBay
/ Welding cast iron #16
Only one with low self-esteem and lack of confidence would hire it out after buying equipment to do it them selves. Go for it and ask for help if you don't like how it's looking.
/ Welding cast iron #17
Just off de cuff here, every piece cast is a whole new adventure, but what do I know, only been doin such since I learned to back when done with war surplus airplane piston rings and a O/A torch. Pretty much how it done back den. Course we didn't know it couldn't be done so dat how it was done.
Ders 2 kinds cast iron, good and CRAP. You generally tell by lookin at what casting was designed for to do. 7 dollar word 'metalurgy' gets thrown around a lot. Dat generally translate to your guess as god as mine. Go back to design purpose and calculate what was cheapest for maker. Engine blocks is good quality cause dey gotta be, pots & dutch ovens generally crap. Stove parts wid baked on porcelain absolutely NOT gonna weld or braze. You dont wanna know how dat porcelain fly off and stick to you either. Whole special group wood & coal burning stoves and boilers. You only gonna know how good casting was when it cold and hopefully not cracked to #e!!.
How you gonna connect hunks back together absolutely depends on how much customer willing to spend and how mad he gonna be if repair don't work. Next step in job is knowing or figuring out what process got best chance of success dat gonna endure when put back in service. I can stick together pot can be ground up and painted to sit in corner for decoration probably 90% of time, but same pot going back to work on top of stove or in fire success be maybe 5%. Either way gonna take time and time = money. Got a old cast iron coal fired water heater sittin on porch wid a plant growin out of it. Price was no object when fellow dropped off for fixin to make his wife happy. No way was he payin for 10 hours of fittin & fussin when he came to get, so I kept.. OK, I find a use, and I chalk dem hours up to tuition.
Flange on blower in picture, we can all see it broke. Can I 'fix' it? SURE Before I start tho, what does flange do? Is it suport dat holds blower to bottom of forge or just connection between blower & tyre? Makes big difference in fix.
How I make repair? Depends. What flange does and what mate looks like kind of governs decision. How much $$$ you want to spend big part of decision too. Come to pick up and yell at me how you could have bought new for less and my 18 pound hammer make it real easy for you to go buy new. Truth is if casting stays below 400f, best & cheapest repair is JB Weld.
Choices = Brass, 309ss rod, high nickel rod, Everdur either gas or carbon arc applied, and ever present E70-s6 MIG wid Co2.
Which choice is function of end result required, nothin else.
BTW, casting in picture looks like real crap dat foundry cast cheap as possible. Flange was designed to fail.
/ Welding cast iron #18
And .......the DIY owner of this "real crap" casting has MAYBE a 1% CHANCE of a lasting fix?
/ Welding cast iron #19
Another fun cast repair alloy is cast iron itself. When I was working at JW Harris back in the day I played around with a product called Kastweld 111. Not sure they have it anymore but Weldcote Metals has it called CASTIRON. Uses a flux and is an oxy-fuel product. It is simply ground cast iron stamped into a rod. You can put it on as thick as you want to and it color matches perfectly. So in the end there are a dozen ways to fix this including tacks of 309L stick followed by spray powder. Go ahead and fix it one of the above mention ways. If it breaks just pick another process and fix it again. Soon you won't even need to ask for help. Good Luck.
2021 BOBCAT E32I EXCAVATOR (A62129)
2021 BOBCAT E32I...
UNUSED JCT 72" HYD TILLER (A62131)
UNUSED JCT 72" HYD...
2021 Kubota SVL75-2 Track Loader (A63118)
2021 Kubota...
2013 JOHN DEERE 7700 PRECISION CUT FAIRWAY MOWER (A62130)
2013 JOHN DEERE...
2016 Ford F-150 4wd 4 Door (A63118)
2016 Ford F-150...
2016 Ford F53 Motor Coach, VIN # 1F66F5DYXG0A01790 (A61165)
2016 Ford F53...
