Tilt trailers
/ Tilt trailers #1
MoMower
PA
Massey GC1710.
Looking to add a manual tilt, 6.6’x16’ 10k trailer to my fleet. Just looking for input on functionality, recent cost, etc.
Main use will be hauling my SCUT and extra implements to jobs. I currently do this with a 6’x12’ dump trailer.
I have got one quote so far, $5799 for Bri-Mar.
/ Tilt trailers #2
Trailers are a lot like cars. Different brands have different levels of quality, options and during Covid, availability. I cannot get the dump trailer in the configuration I want. Trailer manufacturers are building the best sellers right now and discontinuing slow moving designs.
Have you checked out Appalachian and Kaufman? They are great on pricing.
/ Tilt trailers #3
Have you decided 'split deck' or 'full tilt'?
I looked at tilt trailers for awhile but finally settled on a stationary and I'm happy with it. Can sure see where they are good to have in some situations.
$5,799 sounds like a good price on a tilt trailer. Depends on the trailer.
/ Tilt trailers
With some further research Kauffman ($1000 less than Bri Mar) and Cross Country look good, price wise. Have to do some more digging.
I’m thinking full tilt, but that may change.
/ Tilt trailers #5
I have a Kaufman. They claim to build over 500 trailers per month.
Made in North Carolina.
Check out Appalachian, too if money is tight.
If you want to spend more check out Diamond C or Belmont
/ Tilt trailers #6
Is 16' going to be long enough for your SCUT and a few implements?
How many, and what size implements have to go along on the same ride with the SCUT?
/ Tilt trailers #7
He could get more storage on a gooseneck with a deck on the neck ;)
/ Tilt trailers
Do you like your Kaufman?
/ Tilt trailers
16’ will do, but most I’m looking at are 18’ or 20’.
Usually the tiller and BB, along with the BH attached.
/ Tilt trailers #11
Always always always buy a bigger trailer than you think you need. The size only seems intimidating for a few weeks, then you get used to it.
You can always live with a few feet of unused trailer deck, but you can never stop wishing you bought a bigger trailer when your equipment won’t fit!
/ Tilt trailers #12
Have 16' Imperial equipment trailer (steel deck). 20' would be better. Electrical issue - all lights are on deck. Bad electrical contact at tilt swivel and lights don't work. Add a ground wire from deck frame to trailer tounge
/ Tilt trailers #13
You might check with this outfit, they are in PA. 20' power up and down for less money.
2;) PJ Trailers 83" Hydraulic Quick Tilt (TH) 2’ T215 | Fayette Trailers LLC
What I don't like about a tilt bed is the axles are too far forward. Depending on the load it can be hard to get hitch weight. The longer the better to help offset the axles better and allow for better load placement.
/ Tilt trailers #14
/ Tilt trailers #15
22 PJ Trailers 83" Hydraulic Quick Tilt (TH) 2’ T215 | Fayette Trailers LLC
Although I wasn’t able to make a deal with them, they were nice people to work with.
/ Tilt trailers #16
I concur. The last 15-20% or so of a gravity tilt deck really can't take any load if you want proper tongue weight. A small fixed deck in front helps balance them, but due to the deck pivot, most have their axles way to far forward. My old gravity tilt really couldn't be towed empty. You needed to add weight up front to prevent fishtailing.
I had a 16' gravity tilt. Beefy trailer, nice & low, easy to load a tractor on. But its was way to short. Also due to a lip around the side & fenders, it sucked to load anything on that couldn't drive on.
I was expecting to get another gravity tilt. I ended up with a 22' Diamond C deckover power tilt. It's OK to load a tractor on. Pretty steep deck when tilted & implements often scrape a hair. But forking a pallet over the side is trivial. If I were to replace the new trailer, it would be a tough choice to stick with a power tilt deckover or go back to a lower gravity tilt. I mostly haul the tractor, which is marginally harder to load, but hauls other stuff better. A gravity tilt has a noticably lower deck, which is better for loading a machine on & more stable on the road. You only get 82" or so between the fenders, unless you go for a deckover that can be up to 102" wide. Some trailers have drive over fenders to split the difference, but I've never used one.
My flail mower won't fit between fenders, so that rules out most gravity tilts for now, unless I can balance out properly driving forward. I back on now & am not sure if I could balance pointed backwards on a 20-22" deck.
Gravity tilt deck is shining high, deckover is about crotch high. IMG_20140209_103755.jpg20200730_165041.jpg
/ Tilt trailers #17
Don't buy a cheap one. I've seen u tube vids on their weak points
/ Tilt trailers
So far Kauffman is in the lead. $5200 for the “deluxe”, adds rub rails, tool box and a bit better built. Would be a 14k derated to 9999. 82”x20’, 6’ fixed front deck, spare wheel and tire.
Just have to figure out if I want to run for it, 14 hour round trip, or pay $400 for delivery.
Waiting on a quote from Cross Country Mfg.
/ Tilt trailers #19
I was busy as heck, so I had mine delivered. Glad I did. It would have cost me a lot in diesel, tolls and trip permits.
/ Tilt trailers
Plot twist, may have found a 1 year old Appalachian, locally. Same specs as the Kauffman for $4600.
2014 Freightliner 114SD Grapple Truck, VIN # 1FVHG3DV2EHFV3934 (A65563)
2014 Freightliner...
2024 Ford Transit Box Van, VIN # 1FDRU6ZG8RKB10273 (A65563)
2024 Ford Transit...
1999 Van Hool Transit Bus T2100 Bus, VIN # YE2TC63B3X2043319 (A65563)
1999 Van Hool...
IH International 1466 Tractor (A66285)
IH International...
John Deere 920 (A64126)
John Deere 920...
2018 Deere 310L EP Backhoe (A64126)
2018 Deere 310L EP...
