Buying Advice Kubota B2650 to LX2610
/ Kubota B2650 to LX2610 #11
No. It will lift X at the pins. X may include different mounted attachments and the net load will vary but the rating will not change. That is exactly why the rating is established at that point.
/ Kubota B2650 to LX2610 #12
In my opinion the LX looks better than the B50 series. The slightly higher hood makes it look more well proportioned to the cab. To me the B looks like a giant cab on a tiny tractor.
Well, no cab.
/ Kubota B2650 to LX2610 #16
If you look at the specs in my post, you'll see that the la535 has less capacity than the previous la534.
I want the 2.2 pounds I am paying for! :hissyfit:
Not sure if this is relevant in your case but LX tractors equipped with the mechanical self-leveling package have reduced payload vis a vis those without self-leveling due to the parasitic weight of the self-leveling hardware.
SDT
/ Kubota B2650 to LX2610 #18
:thumbsup: Yeah Paystar.....but it's what's under the hood that counts.........:laughing:
Cheers,
Mike
/ Kubota B2650 to LX2610 #19
Well, that is possible , but the
lift capacity (pivot pin)
wouldn稚 be affected by the ssqa would it?
I believe the SSQA does effect the rating. I recall that my BX25D was rated a bit higher than the follow-on BX23S due to the BX23S's newer SSQA. Additional weight of the SSQA FEL assembly (sans attachments) in front of the pin would still proportionally effect capacity at the pin, but at a reduced amount, right?. Good luck...
/ Kubota B2650 to LX2610 #20
Just for reference, the last digit is just the loader series, the first 2 are approx lift capacity in kg, so the 534 and 535 should have the approx the same often capacity, but as stated standard accessories can decrease the total capacity.
The ssqa is standard on the LA535, so that might be the small decrease in total capacity that you're seeing
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
MACK T/A DUMP TRUCK (A58375)
MACK T/A DUMP...
2015 JLG Skytrack 8042 (A60462)
2015 JLG Skytrack...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
