Snow Old BX Front Quick Hitch VS. New 4-Point
/ Old BX Front Quick Hitch VS. New 4-Point #1
robertm
Northern Illinois
Kubota BX2660
Anyone have first hand experience with both that can provide insight of one over the other?
I'm looking to either add a front blade to my BX2670, or move up to a BX2680. Doubt I'll ever look at a snowblower, so the new front shaft coupling is of no real concern.
Lots of talk here about using the old style front QA with the 80-Series, but none using the new 80-Series on an older series, like a 70. I guess if the new 80 series fits the 70 series, it should work in retro?
Holy Smokes! 243 views and not one viewer has upgraded to an 80-Series from an older Series. Maybe the front QH isn't that popular. Sounds like I'd just go with the 80-Series anyway.
/ Old BX Front Quick Hitch VS. New 4-Point #3
Sorry Robert, I can't help you other than to bump this thread. Good luck.
/ Old BX Front Quick Hitch VS. New 4-Point #5
The front QH reduces the already low carrying capacity of the BX FEL.
509 lbs vs 423 lbs average load and 739 lbs vs 613 lbs at the pin, that's a 17% reduction from what I already consider bare minimum capacity.
Wrong QH. You are thinking QA on the FEL. I'm speaking of the Quick Hitch (4-point) that mounts to the frame and accepts the blade, snow blower, or sweeper. I see I did type QA in my post, but I meant QH, as noted in the title. Sorry.
BTW, I run Jerry Dunn's QA on the loader of my BX2670, so I lose minimal in weight, but the new SSQA on the 80-Series... well... that loss just plain stinks.
/ Old BX Front Quick Hitch VS. New 4-Point #7
Hi there,
I know the SSQA was not the topic of your post but this comment caught my attention, as I'm looking into getting a BX-series. Can you expand on the portion of your comment that I bolded, above?
Thanks.
/ Old BX Front Quick Hitch VS. New 4-Point #8
Don't know if this helps...
/ Old BX Front Quick Hitch VS. New 4-Point #9
I had the old style front hitch on my 2 recent b’s and after watching messicks demo of the new style I can say that the new appears to be easier. There is one less shaft to hook up and less fussing to get the blower or plow lined up for connection.
Hi there,
Thanks.
Jerry Dunn’s QA for the loader weighs a fraction of the SSQA Kubota adopted for the BX. Plus, if you use forks, any of the SSQA fork setups are very heavy compared to Jerry’s forks.
With the minimal weight of Jerry’s QA on the loader, I gain that in loader or fork capacity. I have managed close to 1,000# with my forks, carefully managed, but verified with weights calculated per paving brick. An 80-series with the SSQA won’t come close from the sheer loss in capacity due to the weight of the SSQA on the loader, the weight of the forks or loader bucket with the heavy plate adapter, and then, the distance the SSQA moves the load out.
/ Old BX Front Quick Hitch VS. New 4-Point #11
+1 for Jery's QA and adjustable forks.
/ Old BX Front Quick Hitch VS. New 4-Point #12
I have a new BX2680 with the front plow setup. It is very HD, and works great for plowing snow.
Dave
I have a front blade on my BX2670. In the Midwest, I will NEVER be without one again. I absolutely love this blade with full Hydraulics. So easy to remove and put back on, too. Had a whole house genset installed last week. Had to take blade and frame off to use loader to clear area for genset. Guys wanted a path cleared in the snow to roll cart with genset into position. I said “Nope. We’ve got forks for that, and then used them to unload genset and carry to the final location. Blade went back on in 5 minutes. Why I ever bought a rear blower, I’ll never know. After four years and one pass down the driveway, I sold it for what I paid for it. Now, we’re on year five, and STILL have not seen a winter worthy of a blower. I’ll use my loader if it’s that bad.
2016 PETEBILT 579 69 SLEEPER (A62613)
2016 PETEBILT 579...
INGERSOLL RAND  G25 GENERATOR (A60736)
INGERSOLL RAND...
2015 Komatsu HM400-3 Articulated Dump Truck (A60352)
2015 Komatsu...
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
2001 Peterbilt (A60352)
2001 Peterbilt...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
