CalG
Super Member
- Joined
- Sep 29, 2011
- Messages
- 9,394
- Location
- vermont
- Tractor
- Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
OK, I don't get it.
The BIG SNOW came Wednesday night . I put the Kubota B7200 battery on the 1 amp trickle charger overnight in order to assure a good start at 6:00 Thurs. morning so I could clear a way out of the drive. That little dynamo just never leaves the battery topped off.
Wade out to the open tractor shed through the knee deep fluffy snow in the morning darkness. Unclip and stow the trickle charger, swing a leg over and set down. Hold the key in the "GLOW HEAT" position for the slow count of 30. Turn the key to run the starter motor. Whirr Whhrr, chuff chuff, a bit of black smoke, But no start. Lather rinse repeat until the battery just tells me, "No MORE".
Clip on the trickle Charger, and start up the gas tractor with the push blade and clear enough of a path to get out.
Come back home in the evening after having the trickle charger on all day. A repeat of the above described performance.
In disgust, I hook on the 6 amp charger to replace the 1 amp trickle and go in to have supper.
Trudge back to the tractor shed about an hour later, after a pleasant supper with my wife.. Unhook, swing a leg over and into the seat, hold the key in "glow heat" for the slow count of 30. Dang thing starts RIGHT UP without fanfare.
What a puzzle!
No real benefit to having it start. The impeller shear bolt failed after only about 60 feet of blowing. Early season rocks! ;-(
But why did it start right up?
Temps were around 15 degrees the night before, and all day, might have hit 20 mid day while I was gone.
What a puzzle!
