plowhog
Elite Member
- Joined
- Dec 8, 2015
- Messages
- 3,858
- Location
- North. NV, North. CA
- Tractor
- Massey 1710 / 1758, Ventrac 4500Y / TD9
Just getting started with my Farmi 351p logging winch. I recently played out the cable, and winched it back under load. So its now ready for some logging work, but I have a few questions:
I want to winch a fallen oak limb out of a forest to a clear spot, only about 60-80 feet. The limb is about 12-16" in diameter, 30-40 feet long. It is up a slope. My tractor access is from below. I need to winch it, almost straight downhill, to the clearing so I can grab it with my grapple.
The Farmi manual says: "Do not winch downhill." Is that for real? It is a somewhat mild slope. Is there any "gotcha" I should know about pulling down a mild slope? The Farmi manual shows a (prohibited) pull down a slope, with an ending crest higher than the tractor. It looks like the log could crest the edge then with continued winching the end could land and fall on the tractor cab. Nobody is that stupid, right?
Next, I have another limb (about the same size) I want to pull sideways along the same slope. Not up or down, but laterally. It is a very straight limb, hardly any bends. If I hook onto it, and start to pull, there seems to be enough side slope where the limb could potentially roll downhill. If that roll began with my cable still attached, it would become a ... bad day. Not to mention there is a building in the path where it could roll.
Is there a good trick to "side winching" along a slope, and eliminating the chance for a limb roll along the way?
btw, yes these limbs are 12-16", sometimes larger. They are fallen limbs from some very large black oaks ....
