Why does starter fluid cure my no start? What is the issue?
/ Why does starter fluid cure my no start? What is the issue? #71
Never heard of a broke choke shaft on a small engine. Or are you talking about a broke choke cable, seen many of those. Glad you found the problem. :thumbsup:
/ Why does starter fluid cure my no start? What is the issue? #72
I don't know if he ever said which engine. Kohler at times will have a a little choke wizard w/ a spring control on it at the end of the shaft. They break at times. On some they have gone to their Smart Choke system.
/ Why does starter fluid cure my no start? What is the issue? #73
I’ve seen where the choke plate comes loose on its shaft so the plate doesn’t move.
Thank goodness the OP put this to rest, the debate on starting fluid, propane, summer gas, av gas would have gone on for weeks.
/ Why does starter fluid cure my no start? What is the issue? #74
Who said the debate is over? :stirthepot:
/ Why does starter fluid cure my no start? What is the issue? #75
Perhaps the OP will now not be able to get the oil drain plug out?
/ Why does starter fluid cure my no start? What is the issue? #77
Do the pallets even have drain plugs??
/ Why does starter fluid cure my no start? What is the issue? #78
That will take 2000 posts to resolve and require us to ask Kando for advice.
/ Why does starter fluid cure my no start? What is the issue? #80
Spill abatement pallets generally got drain plugs.
2018 Isuzu NPR Cab and Chassis Truck (A59230)
2018 Isuzu NPR Cab...
(INOP) 2011 FORD F-150 XL SINGLE CAB TRUCK (A59823)
(INOP) 2011 FORD...
KUBOTA M6S-111 TRACTOR (A59823)
KUBOTA M6S-111...
FORD 6610 TRACTOR (A59823)
FORD 6610 TRACTOR...
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A59231)
2019 Harley...
2012 BMW 328i Coupe (A59231)
2012 BMW 328i...
