Why does starter fluid cure my no start? What is the issue?
   / Why does starter fluid cure my no start? What is the issue? #71
Never heard of a broke choke shaft on a small engine. Or are you talking about a broke choke cable, seen many of those. Glad you found the problem. :thumbsup:
   / Why does starter fluid cure my no start? What is the issue? #72
I don't know if he ever said which engine. Kohler at times will have a a little choke wizard w/ a spring control on it at the end of the shaft. They break at times. On some they have gone to their Smart Choke system.
   / Why does starter fluid cure my no start? What is the issue? #73
I’ve seen where the choke plate comes loose on its shaft so the plate doesn’t move.
Thank goodness the OP put this to rest, the debate on starting fluid, propane, summer gas, av gas would have gone on for weeks.
   / Why does starter fluid cure my no start? What is the issue? #74
Who said the debate is over? :stirthepot:
   / Why does starter fluid cure my no start? What is the issue? #75
Perhaps the OP will now not be able to get the oil drain plug out?
   / Why does starter fluid cure my no start? What is the issue? #77
Do the pallets even have drain plugs??
   / Why does starter fluid cure my no start? What is the issue? #78
That will take 2000 posts to resolve and require us to ask Kando for advice.
   / Why does starter fluid cure my no start? What is the issue? #79
   / Why does starter fluid cure my no start? What is the issue? #80
Spill abatement pallets generally got drain plugs.
2018 HONDA RECON 250 4-WHEELER (A51247)
2018 HONDA RECON...
2011 CIRCLE M 32 FOOT GOOSENECK (A53843)
2011 CIRCLE M 32...
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
173 (A55851)
173 (A55851)
UNUSED FUTURE FT 72 PRO 72" HYD MULCHER (A57193)
UNUSED FUTURE FT...
