Got spacers in, can't break wheel bolts/nuts - what next?
   / Got spacers in, can't break wheel bolts/nuts - what next? #11
A tight fitting socket works best with a impact.
Well to answer bearthebruce, the hardware looks great. No rust, no paint.
I just bought a new complete 1/2" drive set - never thinking I'd ever use a 3/4" :)
I have to believe that the 30" breaker bar with my son & I on it to make sure it stays on the heads will be enough. I do have a 30" 1-1/4" pipe nipple in the garage, jic.
I'll let you know what we break.
   / Got spacers in, can't break wheel bolts/nuts - what next? #13
A little touch of a propane torch on the nut only can be helpful.
   / Got spacers in, can't break wheel bolts/nuts - what next? #14
You’ll be fine with all that.
   / Got spacers in, can't break wheel bolts/nuts - what next? #15
On my backhoe I had to use a 3/4" pull handle with a 6' pipe on it.
I did buy myself a 3/4" HF impact but I don't have a good enough compressor to run it. I added the HF version of high flow fittings to my compressor and hose. Planning to upgrade to a two stage 175 lb compressor with 1/2" hose at some point. The only thing I tried the impact on was a piston bolt for a 4-1/2" bore crowd cylinder. Didn't touch it. I took the piston and rod to the yellow JD dealer and they pulled out the exact same HF gun I bought and zapped the bolt right off. I didn't ask what pressure they were running but they did have a large diameter air hose. Looked to be 3/4" but it may have been 1/2".
Success! My son hasn't come home yet so I decided to try one more time with the 30" breaker bar. The WD40 has been on now for several hours. Maybe that did the trick?
otoh if I was 50 years younger maybe it wouldn't have been so bad :) Thanks to all!
Just finished the install of one - us 74 yo's move slower :)
short some of their 'special' nuts. Will have to email them tonight. For a while looks like the tractor is going to be lopsided :)
   / Got spacers in, can't break wheel bolts/nuts - what next? #19
   / Got spacers in, can't break wheel bolts/nuts - what next? #20
A 3 foot piece of black heavy wall gas pipe from Lowe’s works great as a cheater bar if your impact doesnt work. I have one that is 30 years old that I have to use every few years.
1980 Great Dane Low Boy (A57148)
1980 Great Dane...
Bolens Weedeater (A57454)
Bolens Weedeater...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
TOYOTA 8FGCU30 FORKLIFT (INOPERABLE) (A58216)
TOYOTA 8FGCU30...
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
2020 DRAGON ESP...
