Got spacers in, can't break wheel bolts/nuts - what next?
   / Got spacers in, can't break wheel bolts/nuts - what next? #51
Right, but we don't get anywhere near rated torque from an air-powered impact gun when we use the common size fittings and 3/8" hoses that work for most other things.
There's another size 'up' in fittings and 1/2" hoses can be plumbed from tank with their own pressure reg. Milton has a nice hi-flow tweak on the classic size, with a bit more than the 3/16" hole we've been choked down to in any of the now color coded types.
I have a nice 3/4" impact gun that even with better flow has shown limits that were surpassed by a cheapo breaker bar and say 30-42" Johnson-bar.
btw, I don't like to resort to the blue wrench on painted stuff. Gibbs trumps Kroil, 50/50 ATF & acetone is tops (shake well, repeat apps mostly or all acetone) Blaster and Liquid Wrench have good products. All benefit from soaking and re-applying. (you guys knew that :))
   / Got spacers in, can't break wheel bolts/nuts - what next? #52
I'm late to the party as usual. It sounds like the OP has his upgrade under control. However, I'd like to point out that while WD-40 works as a lubricant, it really isn't a penetrating oil. Some of the fluids mentioned by other posters work much better.
There is another penetrating oil product that was designed for the aircraft industry that I have had great success with on severely rusted bolts called "Mouse Milk".
I have no idea where that name came from :D. And everyone here has gone through all of the possible jokes on the name! :laughing:
But the fact is the dang stuff works better than any penetrating oil I have come across. Takes just a few drops and if you let it sit for several hours that odds are good that a rusted bolt will easily break free. It was amazing how it loosened 1 1/2" bush hog blade bolts that had been on for 30 + years. You still need good wrenches and breaker bars, but you minimize the risk of wringing a bolt in two. It is expensive and can be ordered on line. But no where near as expensive as drilling out a broken bolt. W. Jones
Just had to resurrect this thread and say thank you 52wej! My L3800 can to me with a terminally seized 3ph speed control. I had tried WD40 and then some highly recommended penetrating oil. With a Channellock on it I was able to make it 'squeak' once. You know, that squeak just before you have 2 shafts instead of one :(
I ordered in the Mouse Milk, put it on the shaft and let it sit overnight. Literally I can turn it with 2 fingers now. It's magic!
Thanks for posting the info.
48x4 Mini Skid Trencher (A56436)
48x4 Mini Skid...
2019 TAKEUCHI TL12V2 SKID STEER (A52709)
2019 TAKEUCHI...
CFG Industry MX12RX Mini Excavator (A57149)
CFG Industry...
UNUSED FUTURE SZYMJ HYD MINI SIDE SWING STUM GRIND (A58376)
UNUSED FUTURE...
2015 Bradco Paladin HDB96 6 Way Blade Skid Steer Attachment (A59213)
2015 Bradco...
2019 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A52709)
2019 GENIE GS-1930...
