400 hour Service Advice
/ 400 hour Service Advice #11
Nothing a few rags can't clean up. And if you do it yourself, you know its done properly. The dealer (like mine) might even have a kit for you. I did my full service this spring and it wasn't bad.
/ 400 hour Service Advice #12
The fuel line on my 2013 Kioti CK30H developed a slight leak this spring at 400 hours. The fuel line is standard diesel fuel hose about 4 inches long and fastened at each end with standard hose clamps. The fix took about 15 min.
/ 400 hour Service Advice #13
The HST fluid is easy enough to change. I use a deep Tupperware storage tub and empty it at 5 gallons so it's easier to handle. If the trans and hydraulic filters are original, they may be difficult to remove - plenty of threads here on best ways to get them off.
I have never replaced a fuel line, hose, or belt on a schedule.
You didn't mention coolant. If you haven't changed the coolant, I would definitely do that also!
/ 400 hour Service Advice #14
I got a large ~14 gallon drain pan that fits under my Branson. It's trans holds close to 10 gallons. 5 gallon buckets won't fit under the trans.
I prefer to do this kind of work in the summer when I can. Lying on cold hard concrete is worse than lying on cool hard concrete in the summer.
/ 400 hour Service Advice #15
Plus the oil is a lot thinner in the summer months, drains a lot easier.
/ 400 hour Service Advice #16
I'd think that you could easily change the engine oil and Hydro oil. If the hydro filter is sticking out similarly to the engine oil filter, you should be able to unscrew it and screw another in. It had to to tighter because of the higher pressures.
I have never heard of having to replace the fuel line, very weird. I'd ignore it.
On my JD 2025R, think it says to replace the Hydro fluid again at 200 hours after the 50 hour change. All I did was to change the screw-on filter. Way to short to replace all that fluid, and it gets no where near as hot as engine oil nor does it come in contact with anything like blowby from piston rings in the engine.
Ralph
/ 400 hour Service Advice #17
A good question, Dale. You picked up on the context of my post, which is the tractor isn't something that has been neglected and needs a lot of work.
Two things I can think of the dealership should provide, both surmountable by me with some effort at home. One is expertise, but that is increasingly available on YouTube by, IMHO, wonderful people who take the time to do instructional videos. And here.
The other thing is containers to catch many gallons of draining hydraulic fluid. There is a thread where someone said it got out of hand and made a pretty good mess.
Dealer expertise?...... My SCUT (GC 1715) came back from 50 hour service with loose wheel lug bolts where tech had to remove wheel to clean HST filter screen.... Heck even I am capable of leaving lugs loose but probably would not....
Pretty cautious of other people work, when we had tires rotated on the Jeep and wife took off on 300 mile round trip next day.... When she got home the right front was missing two lug nuts and the other three were loose, and the 5 lug nut of left rear were loose.... Needless to say I was quite angry with him and his employee .....Thankfully for all the locals safety the shop owner left town or quit the business....
It maybe just me, but anytime anybody works on any of my vehicles I check the work now ..... Probable would take me just a little bit longer to do the work my self and save a few shekels for the late night hot toddy curled up in front of fire with my wife of 46 years.......
Dale
/ 400 hour Service Advice #18
Seems to me if you go full synthetic and they advertise 10,000 miles (Mobile 1) or some astronomical distance (hours) all you need to do is change filter at correct (hour) intervals and just top up .... Some place on forum was discussion of just removing hydraulic filter and screwing on new one in one motion....And only losing a quart of so of oil....
Dale
/ 400 hour Service Advice #19
Do the full 400 service interval yourself and save $800 on labor costs. It will be like only about 8+ hours work and you can spread that over two days. Just be sure to get enough quality hydraulic fluid in 5 gal buckets, and spread a sizable tarp under your tractor for ground protection. Check the old fluid for metal shavings.
Be advised, if the hydraulic and HST filters have never been changed, they are the original factory install, and very hard to remove because they are painted on at the factory. These two filters can take hours to get off the tractor. So be persistent. Don't forget to include new fuel filter and the air filters too. Grease all zerks on the tractor. Change the coolant if it's really over 7 years old.
Do a visual on all fuel lines and replace if needed. You can get quality fuel lines at NAPA if in a hurry. Bring in a small section of hose to match diameter. Get about 3 feet and cut to the required lengths. Replace all the old hose clamps with new quality stainless clamps.
Don't forget to drain your front axle gear oil, and replace with SAE90 gear oil. Grease all front axle zerks.
/ 400 hour Service Advice #20
I had a fuel line go bad on a Ranch King lawn tractor...it was 30 years old and had ethanol pump gas run through it. I do all my own work on everything that I possibly can and having worked in the pharmaceutical industry for 18 years I'm pretty thorough. Just last spring I replaced the primary and secondary timing chain(s), all four cam phasers, water pump, and countless soft parts on my 2011 EcoBoost engine. It's all just nuts and bolts.
As in my industry, regular and comprehensive inspections can reveal things before they become breakdown issues. The problem is people don't do them or know what to look for.
Do the work yourself and learn!
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
2018 FORD TRANSIT 350 SERVICE VAN (A59823)
2018 FORD TRANSIT...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2019 CHEVROLET SILVERADO LD CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2020 DRAGON 150BBL ALUMINUM (A60736)
2004 Saturn VUE SUV (A59231)
2004 Saturn VUE...
