Milky engine oil
/ Milky engine oil #1
emptyjay
Ford 4600
Looked at buying a 20 year old Mahindra today that had really low hours (less than 300). Generally looked and sounded good except the engine oil was milky both while cold and also after running for a while. No smoke except a little bit starting up. Afraid the oil might signify a cracked head gasket or some other major issue although the seller says he thinks it's just condensation from sitting for a long time. The asking price is probably what the tractor is worth, but not a fantastic deal or anything. Would you guys take the risk? IMG_20201206_095202.jpeg
/ Milky engine oil #3
Hard to say. I know an engine sitting for long periods can get milky looking oil. May take hours of high rpm running to clean it up. But it may also indicate no routine maintenance done. I would never let my oil get like that. Probably id pass also.
/ Milky engine oil #4
Ask seller to change oil and filter. Ask if you can run tractor a while and then send recently changed oil in for analysis
/ Milky engine oil #6
Its a 50/50 shot , How much money can you afford to lose....
/ Milky engine oil #7
Run! Unless it’s free.
/ Milky engine oil #8
Even if the asking price was deeply discounted, I would pass.
Just way too many options out there to put up with this garbage. You'd think a guy trying to sell something would put in some effort to get it into it's best condition possible before the sale. The fact that *this* is it's "best condition" speaks volumes about the equipment, and the guy owning/running it.
/ Milky engine oil #9
Pass. You don't need the headaches.
/ Milky engine oil #10
Excellent point! It always amazes me what little preparation people do in getting something ready to sell. They put up a piece in crappy condition and then want top dollar.
/ Milky engine oil #11
Nope... tell him to change the oil and run it. Check back later and see what the story is if you are hard on this one. Got to be others out there to compare. 300hr is extremely low for 20 years. Might have other issues with dried seals, fluid maintenance, etc. Does sound like it sat a lot and the owner wasn't routinely running/maintaining.
/ Milky engine oil #12
Looked at buying a 20 year old Mahindra today that had really low hours (less than 300). Generally looked and sounded good except the engine oil was milky both while cold and also after running for a while. No smoke except a little bit starting up. Afraid the oil might signify a cracked head gasket or some other major issue although the seller says he thinks it's just condensation from sitting for a long time. The asking price is probably what the tractor is worth, but not a fantastic deal or anything. Would you guys take the risk? View attachment 678936
Milky oil is commonly due to water in the oil. Sounds to me like you know that. It used to be that the oil vs water would stratify if the oil was left to sit long enough, but now most times it won't separate because of the high detergency in modern oils.
It's not impossible that it would be condensation, but I've never seen an engine with that much just due to condensation. Back when vertical exhaust pipes were common, it wasn't impossible for water to enter down the exhaust - which is why vertical stacks have a flapper on them. Or a tin can.
More recently us old mechanics are talking that we have begun to see cars, trucks, and tractors arriving from flooded areas that still have water throughout the engine, transmission, and rear end from being submerged. So the first thing to check is the oil in the trans/hydaulic system and power steering and front axle if 4wd to see if there is water there.
Anyway emptyjay, I agree with you - it's scary.
It would have to be an exceptional deal to make me overlook the milky oil. Because the only way that leak is minor is if the tranny and rear end and hydraulics don't show any water and all - so it isn't an flood machine - and then when you take the head off and find that the leakage path is either purely through the gasket or has made a trace on the head that is shallow enough that the head can be milled flat to remove the leakage path. So for maybe one or two grand worth of work and time you get a good tractor. But what if the leakage path has also etched the block under the head gasket.... ? Now it is all of sudden way more work. And that's only if the leak is the head gasket. What if it is a porous casting? What if this motor has pressed in liners that are leaking? Ugh and double ugh.
And here is something else to consider....chances are good that one of these things is true:
1. Either the owner doesn't ever check the engine oil - which is never a good thing.
2. Or he does check the oil and knows that it is leaking water into the oil fast enough that he didn't think that it was worth changing the oil and filter to try to hide the fact.
3. It is a flood tractor and the seller hasn't checked the other oils.
Get yourself a good tractor. There are lots of good older ones out there from 20 to 40 years old that just need surface cosmetic work because the owner has let them sit too long. This one doesn't sound quite right. You'll know the right one when you see it.
I got all wordy because I love old machinery, but Tomtint and the others have it right..... Pass. Get yourself a good old tractor. Lots out there.
rScotty
/ Milky engine oil #13
What does a motor cost and add some more for your headaches. If its more than that, pass.
I have friends who have made fantastic deals on equipment like this, but you MUST be ready for the worst case scenario.
This kind of deal isnt for the faint of heart or the unrealistic. It has to be assumed the motor is shot and then some or walk.
A 20 year old tractor with 300 hours??? Man thats a rare find. 15 hours a year? Seems fishy.
What does the rest of the tractor look like? A 300hr tractor?
/ Milky engine oil #14
Water in the oil...yes. Let the tractor sit for a couple of days and pull the drain plug. You will know right a way if it is clear water or antifreeze. I have pulled oil drain plugs before and saw a gallon or two of green antifreeze come out before any oil does, and the oil looks like yours does. So, if I am buying, I'm going to be present to see what comes out. What causes AF in the oil? A block that froze and cracked, cracked cylinder, cracked head or head gasket, or worse. Pull the fill cap on the engine and scoop goo out with your finger. If it is AF....you can smell it.
/ Milky engine oil
Thanks to everyone for all of the replies. I was already 90 percent in the "no" camp, and this confirms my instinct. As I said in my OP, the price was within the range of fair but not amazing. I primarily wanted a Mahindra of this vintage since I have a loader that I can mount on it...I will just wait for the next one to come along.
The seller is a hobby mechanic who buys and resells tractors as a side business. He said he just got this one just a few days ago and didn't have a chance to do the tune up. He did replace the starter which wasn't working but obviously he hadn't changed the oil. I'm glad he didn't because I'm not sure I would have seen the problem otherwise.
Thanks to everyone for your advice and feedback. There is such a great wealth of knowledge in the forum.
/ Milky engine oil #16
Still doesn't ring true... if he is a mechanic, he would have changed the oil and found out what he had. I see even more red lights.
/ Milky engine oil #17
Yeah, he changes the oil and it gets milky again...........time to sell it......cash.
/ Milky engine oil #18
They are called "Tractor Jockeys" and are the last place inexperienced buyers should shop.
/ Milky engine oil #19
Look familiar?
I mean really, this guy put these up like this..
I just shook my head and kept on scrolling..
/ Milky engine oil #20
Look familiar?
Exactly... I don't spiff up my stuff when selling, I clean it up so it looks good without overdoing the detail. Suppose some do that, but I surely don't sell it in a spent condition. :confused3:
UNUSED JCT HYD TREE/POST PULLER (A62131)
UNUSED JCT HYD...
2020 Nissan Pathfinder SUV (A61569)
2020 Nissan...
1997 International 4700 Bucket/Chip Truck, VIN # 1HTSCAAP2VH489823 (A61165)
1997 International...
2016 Jeep Renegade 4x4 SUV (A61569)
2016 Jeep Renegade...
(2) UNUSED 320/70R24 TIRES W/8 LUG RIMS (A62130)
(2) UNUSED...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
