Naked 430
/ Naked 430
I have never had any problem with moisture inside the cab, and certainly not any salt, so that really isn't an issue for me. Some of the wires have been in there for going on twenty years with no problems. If they were on the outside, I would have used shrink tube splices with the soft sealer on the inside..
I had three semis for over 30 years, so I am an expert at wiring exposed to the elements. Only time I had problems was when someone else had ****** with it, like taking the cover off the junction box on the rear of a trailer and not putting it back on, if the wires were damaged, or the connectors to lights or switches failed. So-called weatherproof connectors on wiring harnesses leave a lot to be desired.
/ Naked 430 #42
I have a friend who owns a farm and uses a 430 to mow the driveway lawns and his yard. Last year he started having me do it with my Zero turn and I agreed to it, its easy money and helps him
Anyway, hes considering selling the 430. I dont know the year, but its a diesel, 1150 hours has 60 mid mount mower and remote outlets up front. Has hitch on the back. Overall good condition and runs fine except a crack (repaired) in the front cowling. I think he lightly bumped into a tree. No rust, stored inside.
Whats a good asking price for it?
/ Naked 430 #43
So your a truck driver who drives trucks with wiring systems designed by the truck manufacturer. You are not a system designer, but a user. And yes, often times the designer of wiring systems get it wrong. Sometimes it's because they cut corners to cut cost, but sometimes it's the fault of the assembler in the factory.
You maybe correct about the issues around the wiring inside of the cab. Typically safe from direct contact with rain or snow. My post was just a cautionary advise that perhaps the wiring in the cab could become and issue.
I worked as an electrical system design engineer for 13 years for an over the road refrigeration company. I am well aware of problems that can occur in electrical systems exposed to the elements.
I believe that your approach to the use of sealing connectors is valid.
You certainly seem to have a good grasp of the issues with connectors, and I admire you work on your JD.
Richard
/ Naked 430
Yes, there are both type of problems. Connectors and wiring, both inside the cab and outside on the chassis leave a lot to be desired, Weatherproof connectors have gotten better over the years, but inside the cab, especially on the newer trucks with electronic dashes, they can be a nightmare.
One of the Peterbilts I owned would burn out the headlight switch on a regular basis. I didn't even power the headlights and marker lights directly, only powered the relays for them. I connected an ammeter to it several times, and it never showed more than a 4-5 amp draw, But about every few months the connector would overheat and the switch would burn up. Never did figure it out. Same truck developed an intermittent miss in the engine. Three different shops couldn't figure it out. Finally one injector stopped firing altogether, driver limped it to the local CAT shop and they found a wire had broken inside the injector harness. Same harness they had checked for continuity a month before and found nothing wrong.
A year and a half ago, the other truck with a newly overhauled CAT engine, about 20K miles on it, start running rough and lost all power. Had to have it towed 120 miles to a CAT shop in Indianapolis. After some diags they found oil had somehow gotten into a connector on the ECM. They flushed the connector out and reconnected it, the engine started and ran fine. Cost me over $1300 in all.
Back in the 90's I owned a Cessna 172D with an outdated panel and avionics. In '98 I bought am STCd panel conversion kit and replaced it. I did all the wiring on it and the avionics stack over four months. Everything worked perfectly the first time it was powered up.
Then in 2000 I bought a 1960 Beech Debonair, it also had the original panel and avionics that were marginal at best. In 2003 I bought A Beryl DeShannon panel kit for it and did the same thing to it. I was meticulous about labeling ever wire and hose/tube and made lots of drawings, notes and pictures. It came out great too. The only problem in the entire wiring system was a mis-wired mike jack on the intercom harness that I had bought with the intercom. Swapped the tip and ring wires, and all was good. No problems in the 17 years since.
So I have had a lot of practical experience in different type of electrical systems and wiring. I hate to have to fix anything twice, to I try to do it right the first time.
I considered putting a couple of Metripack connectors on the wires coming out of the switch box to connect to the supply and light wires, but thought that was overkill.
/ Naked 430 #45
BX,
OK Now I'm really impressed. I also am a pilot but not current.
And I never owned my own plane, always rented.
Keep up the good work.
After all the work, and money, you put into the JD, maybe you should just leave it in the garage and use it for parades.
Richard
/ Naked 430
Thanks, I never seem to just fix things up and get them functional again, I like to go the whole route and make it like I want it.
Oh, did I mention that I replaced the tired IO-470 in the Deb with an IO-520? I did all that work myself, under the supervision of my IA. It entailed replacing all the wiring from the firewall forward. That was pretty simple.
I only rented a plane once, while I was refurbishing the Deb. FBO had a Piper Arrow N4217T, so the instructor and I took it up to check me out and I could make a trip up to Gaylord, MI. All went fine untill we returned to the field and the gear wouldn't extend when the gear lever selected down. The instructor extended it manually and we landed with no problems. The shop put it on jacks the next day and the gear worked flawlessly. Glar the instructor was with me for a witness.
Yeah, I'm going to hate to take it out that first time, but it;s a tractor not a show car. I still have to take it to the canvas shop to get the front cover modified so I can get it all snapped together. I has never fit correctly since I've owned it, but just never got around to fixing it. Went over and talked to the guy on Friday, and with his schedule of work, Christmas and Amish Old Christmas on January 5th, he said January 7th is when he can get it in. So if we get snow, I can clear it with the Kubota. So far I don't see much snow in forecast.
Here's a couple of pictures of my birds. The inflight picture of the Deb was before I changed engines and prop.
/ Naked 430
I would guess somewhere in the $7K to $9K area, but like anything, It depends on how bad a buyer wants it.
/ Naked 430 #48
WOW. I was thinking about $2k
/ Naked 430 #49
I guess it would depend on which JD 430 you are referring to;
Pardon Our Interruption
The used lawn mower one no way, $2-$3000.
Ni idea why it named the link the way it did :laughing:
/ Naked 430
Just to finish out this thread, I have finally gotten the refurbishment of my 430 finished. Last thing to be done was a modification to the fabric cowl on the cab so that it fit properly around the hood. I hooked up the blower with my new mount I built to keep the drive shaft happy, and now it's all ready to go.
Weatherman says we might get a few inches of snow in the next week or 10 days, I'll believe it when I see it.
/ Naked 430 #51
Wish that 3rd pic was in focus.. Any chance of that? tks
/ Naked 430
Yeah, I'll get a better one tomorrow.
Edit: Here's a couple before it was mounted on the tractor.
/ Naked 430
Gave the 430 a bath to wash off the winter grime, and get it ready to spend the summer parked in the shop.
She cleans up pretty good for a 28 year old tractor.
/ Naked 430
That is one beautiful John Deere 430.
Thanks. For a little over $300 in powder coating I had the metal tractor parts (seat pan, engine side covers and grille) and the blower parts done. Had to paint the hood, since its fiberglass. Spent some time and elbow grease cleaning up the fabric cab parts too. It helps a lot that it lives inside my shop building.
And even though it's a '93 model, it's only got a little over 1,000 hours on it, even though I use it to mow my 3 acre yard.
UNUSED KJ 42'X30' METAL STORAGE SHED (A62131)
UNUSED KJ 42'X30'...
2018 Unverferth 3955XL Seed Tender (A63116)
2018 Unverferth...
2005 International 4300 Hook Truck, VIN # 1HTMMAAM15H108569 (A61165)
2005 International...
2001 CHEVROLET C8500 FLATBED TRUCK (A62130)
2001 CHEVROLET...
UNUSED KIVEL 48" PALLET FORKS (A62130)
UNUSED KIVEL 48"...
2014 Ford F-450 Crew Cab Landscape Dump Truck (A61568)
2014 Ford F-450...
