1700 Dash display question
/ 1700 Dash display question #1
4wheelfurry
Member
Deep South Louisiana
2009 MF 1540 (sold) 2020 MF 1755M
So I went on and jumped on a left over 1755m PS open station. The dealer let me pick it up over Thanksgiving and we didn't go through all the small details like the dash functions. Well my dash display is stuck on OFF. The cycle button does nothing. If I pull the fuse I can cycle through the settings (I changed tire size, it came with R1 and we swapped to R4). So everything looks to be working but I can't make it display anything with the fuse back in in normal mode, it just reads "OFF". What am I doing wrong? Thanks.
/ 1700 Dash display question #2
Just as a confirmation, my 1754 hydrostatic will sometimes read off when I start up, but pushing the button to the left of the steering column will cycle it thru several screens. I don’t recall exactly which ones or the order, but if you need, I can check that out later and report back.
/ 1700 Dash display question #3
I also have the 1755m PS New and had the same question. Dealer tech came out and thought the Display was bad and was going to order a new one. He checked with AGCO and was told according to my dealer that on PS the Display button does nothing so no MPH etc. The OFF tells you that the PTO is disengaged. Doesn't make sense to me but that's what they said.
Vahrenburg did a youtube on a 1760 cab PS that he showed cycling through the display and showing ground speed... Also the dash is universal to all sizes, you set it up to the size and type of tractor it is going on through the diagnostic mode. So I'm going to have to hit up the dealer for sure now.
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
New/Unused Landhonor Quick Attach Hydraulic Pallet Forks (A61166)
New/Unused...
2024 John Deere 408R Sprayer (A63109)
2024 John Deere...
New/Unused 3 Point Hitch (A61166)
New/Unused 3 Point...
KUBOTA M1871 BRUSH GUARD (A62130)
KUBOTA M1871 BRUSH...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
