Simple chain carrier
/ Simple chain carrier #1
beowulf
Central California Foothills
Kubota L3410 HST, J Deere riding mower
I frequently deal with the issue of how to carry my chains conveniently, and I have dumped and lost chains I had forgotten were in the FEL. I previously built (based on a design from someone else on this forum) a vertical 6" ABS pipe which works, but I find I use that holder for shovels, pruners and other things.
Anyway, now, as long as I have my box blade on the tractor, I have a solution. It is not a total solution and won't work for everyone in all situations or at all times but it works for me most of the time. And an added feature is that you don't have to carry, or drag the chain to where you need it - you can simply lift the 'chain carrier' off the tractor and carry it to where you need it - much easier than wrestling with a heavy chain. $13 at TSC. Looks to be durable. Color a bit bright but may be other choices.
There may be other places on some tractors where this could be hung. Pics of the ABS pipe solution and the new chain-carrier (aka feed bucket). The chain in the bucket is a 20' logging chain.
Sorry guys, I keep getting the same message - "unable to access this site". I can go to the TSC web page by just entering TSC and can there see their products, just can't get to whatever your link directs me to.
/ Simple chain carrier #7
I ran across the large diameter plastic pipe thread years ago on here and it is a winner for me. I mounted it on the right side of my L4400 loader frame, below the loader handle. I keep a couple or three various chains in there. The hooks rest on the lip. It has been just handy as can be.
/ Simple chain carrier #8
IT's not a problem with links posted, its problem with TSC site not understanding their own "links/URL's".... Its the poor cheap design of their site..... Have always had real problems with trying to search for items on their site.... Guess that is what you get with cut rate website builders....
"Search" for SKU number....."222057599" ( just the numbers in search field it does not even understand "SKU:" or quite signs included into search field)
Dale
/ Simple chain carrier #9
I have a pipe mounted vertically on my loader just like the one you are carrying the limb cutters in. Mine has a clean out with a screw in lid glued on top. Haven't lost a chain yet.
RSKY
/ Simple chain carrier #10
Could always weld couple J hooks on box blade for the chain,hope you dill couple holes in bucket for drainage.
Actually, I don't leave the 'bucket' hanging there unless I am going to do something that requires a chain. Those particular 'buckets' provide a nice handle so can I can lift off, carry away and put on easily. Holes in the bucket are a good idea though.
/ Simple chain carrier #12
Safely carrying chain and tools on tractor attachments are used everyday. Good idea with the feed buckets.
/ Simple chain carrier #13
Beowulf: What did you use to attach the 6" PVC pipe to your loader upright?
Actually, it was what I had here already. I will try to attach the Home Depot links to the items I used - or to similar items. To hold the top of the ABS pipe against the loader upright I used an ornamental black T bracket, the horizontal T part was shaped around the ABS pipe. The vertical part of the T slipped nicely into the gap in the loader upright. For the bottom support I used a 2x4 stake holder (or something similar) bent/shaped in a vice to fit my needs and attached it with some self tapping screws into drilled holes. Simple but works fine and lifts off as necessary.
https://www.homedepot.com/p/OWT-Orn...ERCH=REC-_-searchViewed-_-NA-_-206842595-_-N&
https://www.homedepot.com/p/Everbilt-2-in-x-4-in-Zinc-Plated-Stake-Holder-31230/205386640
Some pics of the holder pieces separately below. Earlier photo shows it installed on the tractor.
2021 Cam-Am HD8 (A64047)
2021 Cam-Am HD8...
Trailmobile Van Trailer (A63118)
Trailmobile Van...
2006 Montone AD24465448 30ft. Tri-Axle End Dump Trailer (A61573)
2006 Montone...
2019 HINO 268 4X2 S/A CURTAIN SIDE BOX TRUCK (A59910)
2019 HINO 268 4X2...
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
2005 MACK CXN613 6X4 T/A  DAY CAB TRUCK TRACTOR (A59911)
2005 MACK CXN613...
