2 Wheel Tractor - What will I do wrong?
/ 2 Wheel Tractor - What will I do wrong? #1
yankeelong
Lancaster, Pennsylvania
None
I'm looking to build one of the two wheel tractors more common in China or India. I don't have a ton of land or serious work, so it seems right for me. I'm also interested in it as a project. Pretty standard, 5-10 HP, built with a tow (tongue?) for hauling some small wagons and maybe a way to attach some small implements. I'm a decent welder and a slightly worse machinist, but I can shape steel sheets and assemble engines just fine, which I assume is going to be the majority of the work. I've settled on a 6.5 HP engine from Harbor Freight but outside that, I have very little idea of what I'm doing. Any help at all would be much appreciated!
/ 2 Wheel Tractor - What will I do wrong? #2
Take complete motocycle engine, about 200...250ccm, and just make cooling, reduction gear and leg for chain driven axle.
That’s how we did micro motor hoes, 40 y ago, from 50ccm motorbikes, when everything was too expensive or unavailable.
Only disadvantage is missing a reverse gear.
Why don’t you simply buy a used one?
That痴 how we did micro motor hoes, 40 y ago, from 50ccm motorbikes, when everything was too expensive or unavailable.
Why don稚 you simply buy a used one?
Makes a lot of sense. I'd just like to do it myself, as a project. My need isn't so great that I want to just go out and buy one.
/ 2 Wheel Tractor - What will I do wrong? #4
Welcome to the Forum. :welcome:
If you put your location in your profile, you may get better local/regional help.
In the meantime, look for a David Bradley tractor. Even if you find one without an engine, that will get you a long way as far as the drive train. I had one I found at the salvage yard but sold it to my B.I.L.. He put a HF engine on it and used it for gardening for several years. They're pretty light for plowing unless you're in sand but they'll pull a hoe or rake.
Do a search for "2-wheel tractor" on YouTube. You'll get plenty of ideas. ;)
/ 2 Wheel Tractor - What will I do wrong? #6
One good idea for transmission is an old garden tractor. But for my area, usually can find David Bradley or similar tractors for a few hundred. I know its always great to build something yourself, but sometimes it is easier in the long run to buy it. Plus they have lots of attachments for David Bradley. Or gravely has a step bigger design to look at
/ 2 Wheel Tractor - What will I do wrong? #7
Welcome to TBN.
Following along to see what you come up with.
/ 2 Wheel Tractor - What will I do wrong? #8
I just googled David Bradley tractors. I never knew such a thing existed! I'll be looking at these things for days. Very cool!
I wonder if you could start with a healthy rear tine tiller and build from there.
/ 2 Wheel Tractor - What will I do wrong? #9
When I was a kid my father bought a little two wheel tractor, built a cart for it and we used to pile into the back and ride around the field. SSSHHHH, don't tell the safety police!
/ 2 Wheel Tractor - What will I do wrong? #10
30 years ago a trip to rural Japan or S Korea or a number of other SE Asia countries you would see a LOT of those. Probably larger than what you had. They were the "pickup truck". Unhook the cart and add a ground engagement attachment and they were the "tractor".
I've got a rough idea of what I need, did some research, thanks to the help from everyone on here! Might try to pick up some steel and build a frame first in a month or two.
/ 2 Wheel Tractor - What will I do wrong? #12
Be sure to keep us posted and take pictures. Pictures are good--A lot of the guys here can't read. ;)
/ 2 Wheel Tractor - What will I do wrong? #13
Picked up DB and a couple Simplicity last spring for $200. Haven't done anything wirh them yet. Saved from the scrap pile. The DB does look interesting. Have a couple old Wisconsin engines. One Simplicity has the gearbox with reverse.
/ 2 Wheel Tractor - What will I do wrong? #14
I've got around 26 David Bradley's I've picked up over the years. Most for parts, for the 5 I use gardening. 3 tractors have different cultivators, for different stages of plant growth. Early planting of cole crops, makes those plants much taller than new seedings planted after the frost date, so that means changing out cultivators, as many as 3 times a day. Much easier to just have 3 different tractors set up, with a particular cultivator.
One I have was a parts machine, with no engine I'd picked up cheap. I normally plant atlest 12 dozen tomato plants, plus various other set plants. 3 years ago, I got the idea of building a transplanter to make it easier on my aging knee's, when setting by hand. The wheels in my head started turning in the Fall on how to build it. What took the longest to figure out how to gear it down to just a creep speed. It dawned on me that a hydraulic drive was the was to go. Started searching for an old wood splitter that needed repair, or some TLC. Within a week, I found my donor splitter, a home made unit, where the owner upgraded to a nice big store bought one. Allcomponents were there in one package for 90% of the power unit build. Found a hydraulic motor on ebay really reasonable around Christmas time, when sellers drop prices to reduce inventory.
The planter unit was totally built from scratch. except the spare rear gauge wheels off a DB cultivator I had. I used worn out disc openers from a no-till planter a buddy of mine had, when they replaced the one's on theirs. Perfect size for what I needed. Just removed the hubs, and made my own to fit. Bought an irrigation shovel from Norwest Mfg. for the furrow opener. The closer/hiller's was made from a hiller/middle buster attachment for a Troybilt tiller, cut in half. Packer wheels were old lawn mower wheels. I used the hydraulic control valve of the splitter to engage the drive motor. Routing it through the return/detente position, to turn the hydraulic motor on, and use the OEM DB hand engaged cluthc to start & stop.
Surprisingly it works pretty well. I can set 12 dozen tomato plants in approx. 45 minutes. My aging back an knee's sure appreciate it.
Here's a short video of it on it's maiden voyage, just showing how slow it moves. Even as slow as it looks, setting plants with it, at first felt like it was moving 20 mph. Once I got coordinated with what I was doing, it went much smoother. This year was the 3rd year to use it, and happy to report it still works very well. Well worth the time and money to build. The feeling of satisfaction building something like this is immeasurable. Also couple pics of my other tractors in use in the garden.
MOV2152 - YouTube
/ 2 Wheel Tractor - What will I do wrong? #15
About 60 65 years ago, we had a DB tractor we used for everything. Pulled a mule planter with a chain farming an acre or more of peas and corn and everything in between. I have told this before, we pulled a 2 wheel trailer with maybe a half pickup load of wood hooked direct to the tractor. Had a 2 by 4 bolted to side of trailer to scrub the tire for brakes, a 2 teen operation. Lucky we survived some of the own hill runs but we had to have wood. Better in the 50s than now in lots of ways. GOD Bless Have a good one.
2017 FREIGHTLINER M2 WATER TRUCK (A65643)
2017 FREIGHTLINER...
KOMATSU PC88MR-11 EXCAVATOR (A65053)
KOMATSU PC88MR-11...
Murray Explorer Go Cart (A65640)
Murray Explorer Go...
Metal John Deere Birdhouse (A64127)
Metal John Deere...
2016 Deere 310L (A64126)
2016 Deere 310L...
2009 International 4300 Digger Derrick (A62613)
2009 International...
