YM1510D question
/ YM1510D question #1
Jjpbe
Member
Yanmar 1510D / Kubota L245/ Toro 223D
Hi,
I am wondering what these three holes are for. They are located on the bottom of the tractor under the PTO shaft.
I have attached 2 pictures. ?
/ YM1510D question #2
I suspect they are for drawbar attachment.
/ YM1510D question #4
Hi,
Those are the 3 mounting points for the trailer tow sleeve that the tube and ball would fit into. Not sure if your YM1510 had the square setup or the round one.
I browsed the YM1510 Parts Manual, but the image wasn't there. On a YM2500/YM2610 it's the round version like this ...
/ YM1510D question #5
Hi,
If the Top-Link wasn't there, you would see the tow plate attached with a 2-inch standard ball.
/ YM1510D question #7
sorry about the multiples, TBN would not accept the image, so I keep clicking.
/ YM1510D question
Great info, thank you bmaverick.
/ YM1510D question #9
My round tube draw bar mounts like these photos for the round one show. But the bottom of my case is not recessed ad your tractor pictures show. I wonder if yours used more of a flat stock draw bar.
Threads are most likely a standard metric thread. Clean them out measure depth and diameter, get some 3/4 or 1” bar stock and make your own draw bar if you want one.
Measure the width and length of that slot. Allow yourself about 1/4” of play on each side for with of bar stock. 2.25-2.5 times the length of the measurement of the recess slot.
Make a cardboard pattern an mark the holes. Drill or have some holes drilled for mounting holes. If you want the 2 plate mount like in the round stock photo above, let me know and I will take some measurements of mine and post for you. Or you may not want anything there and use a 3ph drawbar.
/ YM1510D question
Great info CoyPatton. I was looking for one which would fit but now with your info maybe I will make one myself , thank you
/ YM1510D question #11
Yes, I too believe the YM1510 uses a flat bar with a ball setup. This is how the John Deere CUTs are made by Yanmar.
Not sure the hole spacing to make one yourself or to order one like this.
https://www.searspartsdirect.com/product/1bfoj263ca-0071-486/id-23475
The nice thing with a bar like this, you can flip it to get lower or higher as needed for whatever trailer you need to pull.
/ YM1510D question #12
I think - not sure - that all the gray market YM's have a round drawbar and the US models (plus Deere) are flatbar.
/ YM1510D question #13
Look at his photo. It is a recessed area into the housing with 3 threaded holes in the flat of the recess.
I believe his YM1510D would be a gray. But it is built very different from my YM2002D for the draw bar.
/ YM1510D question #14
You build what you can not find to buy. If the mounting holes for that line up, it would have him up and pulling in no time.
Dodge 5500 4x4 Altec Bucket Truck (A63689)
Dodge 5500 4x4...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A63689)
Hobart Champion 16...
Frontier BB5060 (A64126)
Frontier BB5060...
2017 GMC 3500 Enclosed Service Body Truck (A62613)
2017 GMC 3500...
Dodge Charger (A64557)
