HST popping out of mid-range into neutral on downhill
/ HST popping out of mid-range into neutral on downhill #1
beowulf
Central California Foothills
Kubota L3410 HST, J Deere riding mower
Well, I had to recalibrate the pucker factor a couple of times last week. So I am back at the trough looking for answers.
Twice, while going down hill very slowly with a load (boulders on pallet forks for wife's landscaping project) the tractor popped out of midrange and into neutral. AND because I was going downhill (estimate a 15-20% grade on a back road) the tractor took off - startled is too mild a word. I immediately hit the brakes and then figured out what had happened - i.e., it was now in neutral.
Later that day, now in low gear, but otherwise the same circumstances (downhill, very slow, with load), it popped into neutral.
I don't recall this ever happening before. The common factors: downhill, heavy load in front, traveling very slow and cautiously, everything else had been going well all day - a day of dislodging and transporting boulders.
Suggestions? Thanks for any attention you can provide this.
BTW: This has also caused me to rethink how I manage tasks in front of a running tractor.
/ HST popping out of mid-range into neutral on downhill #2
I'm not sure if it is actually popping out of gear but try the same hill again with the heaviest attachment you have on the back and in 4wd and I think you will find it goes much better. Brakes only work on the back wheels unless the 4wd is engaged and since you have a heavy load on the front tracton on the rear tires is limited.
jonsstihl, Thank you for responding. I will check but think it was already in 4WD. The reason I say it popped out of midrange is that the actual lever was in the neutral position each time after the tractor sort of 'took off' on me on the downhill run. I had a box blade on the back during these incidents.
BTW, I have since resorted to backing down the hills in similar circumstances- i.e., heavy load on front.
/ HST popping out of mid-range into neutral on downhill #4
Was it fully in gear each time? Sometimes it's hard to tell. Is the detent functioning correctly?
Good point. My recollection is that I put it fully in gear each time but perhaps I did not. The way I was using the tractor most of time - as I recall - was to be in low as I used my pallet forks to get under a boulder, remained in low as I repositioned on the road, and then at some point would shift into mid range for the trip to the house. It seemed that it went to gear as usual - and sometimes, also as usual- I would have to re-engage and move a bit and then shift if it would not go in at the first instance. Later today or tomorrow I will pop the cover off the range shifter and keep it off for a while as I work. What is interesting is that it happened three times on one day - always down hill and always with a front end load.
Your explanation makes sense! Always look to the simplest explanation first. Thanks for posting. I am assuming by 'detent' you mean the catches that the lever engages when moving into different ranges.
/ HST popping out of mid-range into neutral on downhill #6
Wow, that is a scary event!
Since your brakes worked to stop you it is unlikely the situation was caused by other than the gears popping into neutral I would think.
Not sure why backing down would make a difference, but perhaps someone can add something on that.
As indicated above, perhaps there is something preventing the linkage from going fully into the selected gear. But you would think this would affect the extremes and not mid range. Puzzling...
Henro, it did not pop out when I was going in reverse down hill - that was just something I decided to do due to the very heavy load on the front. It just seemed safer given the load on the front and because it popped out when going forward downhill.
It does wake you up when you are proceeding very slowly and then all of a sudden you are going quite fast downhill.
/ HST popping out of mid-range into neutral on downhill #8
I had an L3410 for many years, and do not recall this happening. It HAS happened twice on my L4060 over the past 4 years.
It only occurred immediately after shifting ranges, and I believe that the range shift was only partially engaged. I now pay closer attention when changing ranges, and also move the machine hard after shifting.
/ HST popping out of mid-range into neutral on downhill #9
soory I missed the part where you mentioned the brakes worked to get you stopped. It does seem like a detent problem with the shifter
/ HST popping out of mid-range into neutral on downhill #10
I have had that happen a few times, and you are right, it can be quite scary. In my case it has usually happened right after I changed ranges and I did not engage the range selection lever all the way into it's detented slot. So when it has happened to me I'd put the blame on the driver, who is otherwise blameless:)
Cougsfan - I am not glad to hear it happened to you but am glad you told me it happened to you as well. And, well. . . yeah, I have to blame the driver as well. Lesson learned.
And on a downhill run it is scary as it really takes off on you. And I would rather blame the driver for this one than have something major wrong with the tractor. It is cheaper to 'fix' the driver than the tractor.
/ HST popping out of mid-range into neutral on downhill #12
I stick my water bottle down by the gear select on the MX because it doesn't fit in the cup holder and it has knocked the selector to neutral a time or two. It is scary. And yes it's my fault.
/ HST popping out of mid-range into neutral on downhill #13
Few or any tractors especially CUTs have front brakes.
With any FEL loads going downhill U should always be in 4WD (AWD) as you then have engine compression working for you.
Loaded FEL removes most weight from the rear wheels.
That or be real fast at dropping your load in order to skid to a controlled stop.
LOL, been there done that! (changed my shorts)
/ HST popping out of mid-range into neutral on downhill #14
I too have had that happen on my LS. I am pretty sure I did not fully engage gears and knocked the shift lever out with my knee while traveling over rough ground.
/ HST popping out of mid-range into neutral on downhill #15
If this was a problem with an automobile there would be mass recalls, headlines, and Congressional hearings.
/ HST popping out of mid-range into neutral on downhill #16
I'm not sure if running in 4WD will help your braking if the transmission is in neutral. Your tractor is 20+- years old, but how many hours are on it?
/ HST popping out of mid-range into neutral on downhill #17
Why not? With 4WD engaged, the front axles is tied directly to the rear axle. Doesn't matter if the tractors is in gear or not.
/ HST popping out of mid-range into neutral on downhill #18
Brain cramp, that's why. ;)
/ HST popping out of mid-range into neutral on downhill #20
I could see a transmission coming out of gear in those situations;
heavy load in the bucket the front tires are compressed shortening the loaded radius considerably,
that in turn calculates into a much decreased loaded circumference, this will take the front axle from a small lead,
to a lag compared to the rear axle.
The rear axle is almost unloaded but is giving a pulsing traction slippage this is the same as backing slightly of the throttle and unloading the gears to shift a manual transmission without using the clutch the down grade is likely giving just a bit of weight to the shifter, the traction pulsing is loading and unloading the transmission the little bit of weight is enough to be like a two fingered clutchless shift.
2015 International TranStar 8600 T/A Day Cab Truck Tractor (A61568)
2015 International...
New/Unused Landhonor 24in Semi-Automatic Tire Changer (A61166)
New/Unused...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2008 Kenworth W900 Grapple/Storm Truck, VIN # 1NKWX40X68J221827 (A61165)
2008 Kenworth W900...
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
2007 Freightliner Columbia 120 T/A Wet Cab Sleeper Cab Truck Tractor (A60352)
2007 Freightliner...
