New LS MT342 loader issues
/ New LS MT342 loader issues #21
I looked at my loader line's this weekend and I have to correct myself. The quick connects at the loader are 3/8" (6600 series) and and then it is 1/4" hose and tubing from there. So the restrictions will be the loader hoses and lines.
A pump that will put out approximately 7-7.5 GPM, quick connects rated at 6 GPM and 1/4" hoses rated, highly marginal, at 3-4 GPM.
I wonder why they went with 1/4? Has anyone looked at a New Holland tractor of the same size? They are LS tractors but New Holland has their own loader. I will have to see if I can locate one and see what size lines they use?
/ New LS MT342 loader issues #23
I can tell you, because my old one was a New Holland and that loader used 1/2" hose and 1/2" OD tubing. It used the same 3/8" quick connects (6600 series).
Would larger hose speed up loader? Reduce lift capacity?
/ New LS MT342 loader issues #25
It would speed it up but shouldn't impact lift capabilities.
If the 1/4" lines are causing a pressure drop due to restrictions then you could see some gain in capabilities by using the larger lines. Don't suspect it would be that large of a change.
New Holland also used smaller diameter cylinders than LS. That would also impact cycle times as well.
/ New LS MT342 loader issues #26
I wonder why they went with 1/4?...
I believe I read in another thread that doing this should help reduce the severity of the floppy bucket syndrome some complained about.
/ New LS MT342 loader issues #27
Yep. Couple different ways they could have addressed that issue. They chose smaller lines restricting the flow. But there are trade-offs with different methods
4ft Mini Skid Quick Attach Rotary Cutter (A63118)
4ft Mini Skid...
ROADTEC RX700 MILLING MACHINE (A62129)
ROADTEC RX700...
Tire Balancer (A61570)
Skid Steer Trencher Attachment (A61567)
Skid Steer...
1997 International 4700 Bucket/Chip Truck, VIN # 1HTSCAAP2VH489823 (A61165)
1997 International...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
