New LS MT342 loader issues
/ New LS MT342 loader issues #21
I looked at my loader line's this weekend and I have to correct myself. The quick connects at the loader are 3/8" (6600 series) and and then it is 1/4" hose and tubing from there. So the restrictions will be the loader hoses and lines.
A pump that will put out approximately 7-7.5 GPM, quick connects rated at 6 GPM and 1/4" hoses rated, highly marginal, at 3-4 GPM.
I wonder why they went with 1/4? Has anyone looked at a New Holland tractor of the same size? They are LS tractors but New Holland has their own loader. I will have to see if I can locate one and see what size lines they use?
/ New LS MT342 loader issues #23
I can tell you, because my old one was a New Holland and that loader used 1/2" hose and 1/2" OD tubing. It used the same 3/8" quick connects (6600 series).
Would larger hose speed up loader? Reduce lift capacity?
/ New LS MT342 loader issues #25
It would speed it up but shouldn't impact lift capabilities.
If the 1/4" lines are causing a pressure drop due to restrictions then you could see some gain in capabilities by using the larger lines. Don't suspect it would be that large of a change.
New Holland also used smaller diameter cylinders than LS. That would also impact cycle times as well.
/ New LS MT342 loader issues #26
I wonder why they went with 1/4?...
I believe I read in another thread that doing this should help reduce the severity of the floppy bucket syndrome some complained about.
/ New LS MT342 loader issues #27
Yep. Couple different ways they could have addressed that issue. They chose smaller lines restricting the flow. But there are trade-offs with different methods
2015 Chevrolet Caprice Sedan (A61569)
2015 Chevrolet...
New/Unused Quick Attach Flail Mower (A61166)
New/Unused Quick...
New/Unused Receiver Hitch (A61166)
New/Unused...
Tire Balancer (A61570)
2016 Kenworth T800 Tri-Axle Dump Truck (A61568)
2016 Kenworth T800...
UNUSED JCT QUICK ATTACH 60" PALLET FORKS (A62131)
UNUSED JCT QUICK...
