What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #1,521
Yeah, without photos, none of it happened!:D
Yes problem i usually have especially when wife comes out after something is finished that has little wow factor but takes a long time ! Haha
I'm also usually so busy doing things I forget to do the before photo so the after might not show it very well !
   / What did you do on or to your LS Tractor today? #1,522
Another stump removal with my MT125. This is the second stump I removed. This one was smaller, but more difficult. Holly tree roots are a nightmare. Didn’t bother clamping on my forks to move It, I just pushed it. IMG_0758.JPGIMG_0759.JPG
   / What did you do on or to your LS Tractor today? #1,523
Stump number Three. The stump wasn’t much in diameter, but was deep. I did at least 5 feet down before the stump would budge. I couldn’t pull it out, but I was able to tip it over a ways and put dirt back over it. IMG_0766.JPGIMG_0767.JPG
   / What did you do on or to your LS Tractor today? #1,524
There is not much going on in this thread anymore these days.
I made some "loader 3rd function" hoses a while back for my last LS XR4140HC. I was going to put them on the new tractor, but decided not to because I have a skid steer and really use that for the grapple and auger anyway.
If you want to know what I did to make them, I have a video about them here: Simple 3rd Function
I did though put on my tractor skid plate I made for my last tractor on this new one and it fit great.
I made a video on that and will upload it soon.
Can't seem to find it in the book .... torque specs for rear wheel lugs?
^^ Nobody? I did about 65FtLbs
Forced the machine to witness the execution of a number of perfectly innocent trees, then aid me in disposing of the remains.
   / What did you do on or to your LS Tractor today? #1,527
I tighten my MT240 to 165 ftlbs. I would think the MT125 would be up closer to 100-125ftlbs at least.
from my manual,
When refitting the wheels or/and rim disk, tighten
the bolts and nuts to the following torques then
check periodically as the instructions of chapter
5 in this manual.
① Rim-disk nuts (M16) : 220 ~ 270 N.m
(163 ~ 199 lbf.ft)
② Wheel nuts (M16) : 216 ~ 245 N.m
(159 ~ 181 lbf.ft)
   / What did you do on or to your LS Tractor today? #1,528
Here is the bolt torque list from page 5-11 of the manual....
Yeah, I saw that, but I'm not sure what size or hardness the rear lugs are. The parts books seems to call them as M12, but doesn't give me the hardness either. I picked 65 since it's kind of in between there somewhere. I can't find the lugs called out separately like the other machine posted above.
   / What did you do on or to your LS Tractor today? #1,530
It should have the numbers stamped on the bolt. If I can remember, I will look at the set I still have.... Remember when there was a discussion a while back on whether the bolts on the wheels should have a tapered shoulder? I still have the complete set that the dealer sent me. I was using spacers, so I never used them.
Bobcat T590 (A53317)
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
1604 (A57192)
1604 (A57192)
2018 John Deere Z997R (A53317)
2018 John Deere...
2015 Freightliner Bucket Truck (A55973)
2015 Freightliner...
2016 KENWORTH T660 SLEEPER TRUCK (A58214)
2016 KENWORTH T660...
