What is the actual difference?
/ What is the actual difference? #1
LD48750
SE, MI
Ford 1510 Mahindra 1526
What is the difference between the 7 tooth star drive sprocket for a 3/8ths chain and one for a 3/8th LP and a .325 Chain?
Length of the teeth?
/ What is the actual difference? #2
If you measure the diameter of each of them, you will find that they all differ from each other a bit. This is so that the ends of the points on the star drive come out at the right distance apart to match the drive link spacing. (I don't use 3/8" LP chain, but I believe there is a slight difference between the 3/8" and the 3/8" low profile. This because the length of the pitch is measured at the rivets. Because the links on 3/8" LP is not quite as tall as on the regular 3/8", it sits differently on the drive sprocket.)
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
2019 PETERBILT PB337 LUBE TRUCK (A63276)
2019 PETERBILT...
2021 Chevrolet Silverado 2500 HD Single Cab Royal Service Truck (A64194)
2021 Chevrolet...
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
2003 Kenworth W900 L Model (A62613)
2003 Kenworth W900...
