Working rail roads and their tracks.
/ Working rail roads and their tracks. #501
What are the ramifications of having an old line no longer used run through a property?
/ Working rail roads and their tracks. #502
It depends. In our case, the railroad officially abandoned it, so it reverted back to the property owners, so just like any other private property now. As soon as they officially abandoned it, most of the farmers that owned land on each side of it scooped up all the ballast rocks to reuse elsewhere and converted it back to farm fields. The section through our place isn't conducive to crops, so we just let it grow over, which stopped the dirt bikers and snowmobilers in a few short years. The section on our place was also the location of a siding about 1/2 a mile long, so the grade is double wide on half of our place. They had to cut through a hill to make the grade and that area of the property is so steep and overgrown that I've only seen the back acre twice since 1989! :laughing:
If they hadn't abandoned it, it would have remained an easement in our case. I wish they would have converted it to a rails-to-trails instead of abandoning it. It would have been nice having a hiking/biking trail right there.
/ Working rail roads and their tracks. #503
Yes, I can read, your point was 14k acres was a big ranch on the East Coast. My point was 14k acres is a small farm in Arizona:laughing:
Yea but 14,000 on the East coast can feed more cows then a million of non irrigated acres in Arizona.
/ Working rail roads and their tracks. #504
I'd say theres 4 scenarios for the most part:
1. It stays abandoned, but the RR company keeps the property ROW-that is what is happening with the rails I just posted pictures of. Its kind of in limbo.
2. It stays abandoned, but the Railroad gives up on the ROW and the adjoining landowners take it over, like Moss just explained.
3. It reverts back to an active Railroad, which just happened in my area between Media, PA and Wawa, PA :) Hopefully it extends even further.
4. It becomes a rails to trails project
/ Working rail roads and their tracks. #505
Any idea when the last locomotive passed through and when were the rails pulled?
Sounds like their could be some interesting finds at least from what the metal detector guys tell me...
Probably not worth reclaiming with some dozer time?
/ Working rail roads and their tracks. #506
Ya, that about covers it. :thumbsup:
/ Working rail roads and their tracks. #507
Trains still ran through there well into the 80's, as I used to have to stop for them when my wife and I were dating. They pulled the tracks and ties sometime before 1989 when we bought the property. The ballast is still there, as is the wooden single-span trestle. Apparently it's still pretty stout, as some doofus the county contracts with drives an excavator over it about every 5 years to clean out the ditch it spans. Hasn't fallen in yet. I may have to inquire about that with my insurance agent. I'd kinda like to have the trestle removed, but I only own half of it length-wise. Property line goes right down the middle.
I've found the occasional spike or plate here and there, as well as a cement marker. I imagine I could find a lot more with a metal detector.
Whenever I need rocks of that size, I go down there with my toothed bucket and grab a load.
/ Working rail roads and their tracks. #508
You have your own trestle??? and it goes over water???
Friends have been trying for years to get to their 9 acres across a small creek with no luck... the old bridge deteriorated... very old and they took it out... funds were tight so they did nothing... ten years later they have the money and county said there was never a bridge there so no luck... where as a repair permit would not be a problem... their bridge dated from the 1920's...
/ Working rail roads and their tracks. #509
Yep. Sounds romantic, but it's a RR bridge over a drainage ditch. :laughing: Water runs all year. Has frozen solid twice since 1989. It drains probably 9-10 square miles and eventually dumps into the Kankakee river, which joins the Des Plaines river SW of Joliet, IL to form the Illinois River, which dumps into the Mississippi at Grafton, IL just NW of St. Louis. The Kankakee river was originally 250 miles long, but was straightened to 90 miles long and drained the Grand Kankakee Marsh, which was known as the Everglades of the North. Interesting story. 500,000 acres drained.
Have you ever gone on Google Earth on a PC and used the time button to go back in time? It shows satellite and sometimes aerial photos of areas going back from just a couple years to as far back as the 30's in some urban areas. Their bridge might show up on it.
/ Working rail roads and their tracks. #510
This map shows the abundance of rail lines through the area. I don't know the date of the map. South Bend is towards the upper right corner.
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
Giyi Mini Ex Attachment Set (A60463)
Giyi Mini Ex...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
Kuhn FC400RG (A60462)
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
