Circular saw arbor problem
/ Circular saw arbor problem #1
BigBlue1
Elite Member
Middle MN
JD: 2520 & x758
So, I bought a nice 10 1/4" Milwaukee circular saw for a project I have coming up that requires cutting and ripping 3" thick maple. It had a dull blade so I bought a replacement. Turns out that the arbor on this saw is 3/4" but there are no 3/4" arbor 10" or 10 1/4" saw blades to be had these days. Apparently that was a standard that was phased out. All blades are 5/8" arbors or diamond.
The spindle on the saw is 5/8" and a 5/8" arbor blade fits over it but the saw's spindle washer (the inside one) has a small lap flange that the 3/4" blade fits over. So the flange is in the way and the blade cannot be run like this. The 5/8" blade is a no-go.
Do I keep searching for a 10" or 10 1/4" blade with a 3/4 arbor? Are they out there?
Do I grind off the flange on the spindle washer and just use the blade I have sandwiched between the washers? The blade's 5/8" arbor opening fits well over the saw's spindle. Not much play. All the lap flange seems to do is center the 3/4" blade, so if the 5/8" fits concentric it's basically the same thing this way. Since the 3/4" blades seem to be a thing of the past it's not like I'm limiting myself in the future.
Do I find a machine shop to drill out the saw blade to 3/4"? I'll have to buy another blade though - one that doesn't have the diamond knock-out - in order to do that.
Thanks for any suggestions.
Rob
/ Circular saw arbor problem #2
Is this inner flange removable? I have grinders that are a similar situation. Also I've seen blades that have a "knockout" for a larger arbor or the older diamond shape on the inside saw flange/washer, but the last one I saw (a couple of weeks ago) was a diamond masonry blade.
Try tapping on this inner washer, or better yet gooble your saw's model #.
/ Circular saw arbor problem #5
You might look for blades with 1" arbor and then use a 3/4" to 1" bushing. I had to do something similar to adapt a dado blade on a table saw once.
Yes, the inner spindle washer is removeable. I could easily take it off and grind the lap flange off of it.
Rob
Yes, that's a possibility. Would that be any better than just removing the lap flange on the spindle washer though and using the 5/8" blade?
/ Circular saw arbor problem #10
Rob
Sorry, I was thinking it but didn't say it....does the "washer" have a flat side or a 5/8 ?
Bush Hog 3715 (A60462)
2025 MMS MS36C (A60463)
2025 MMS MS36C...
YANMAR VIO55-6A EXCAVATOR (A59823)
YANMAR VIO55-6A...
AGT Industrial STSD10 QA (A60463)
AGT Industrial...
10' Container w/ Side Door (A60463)
10' Container w/...
2016 DRAGON SAND CONVEYOR (A58216)
2016 DRAGON SAND...
