Circular saw arbor problem
/ Circular saw arbor problem #1
BigBlue1
Elite Member
Middle MN
JD: 2520 & x758
So, I bought a nice 10 1/4" Milwaukee circular saw for a project I have coming up that requires cutting and ripping 3" thick maple. It had a dull blade so I bought a replacement. Turns out that the arbor on this saw is 3/4" but there are no 3/4" arbor 10" or 10 1/4" saw blades to be had these days. Apparently that was a standard that was phased out. All blades are 5/8" arbors or diamond.
The spindle on the saw is 5/8" and a 5/8" arbor blade fits over it but the saw's spindle washer (the inside one) has a small lap flange that the 3/4" blade fits over. So the flange is in the way and the blade cannot be run like this. The 5/8" blade is a no-go.
Do I keep searching for a 10" or 10 1/4" blade with a 3/4 arbor? Are they out there?
Do I grind off the flange on the spindle washer and just use the blade I have sandwiched between the washers? The blade's 5/8" arbor opening fits well over the saw's spindle. Not much play. All the lap flange seems to do is center the 3/4" blade, so if the 5/8" fits concentric it's basically the same thing this way. Since the 3/4" blades seem to be a thing of the past it's not like I'm limiting myself in the future.
Do I find a machine shop to drill out the saw blade to 3/4"? I'll have to buy another blade though - one that doesn't have the diamond knock-out - in order to do that.
Thanks for any suggestions.
Rob
/ Circular saw arbor problem #2
Is this inner flange removable? I have grinders that are a similar situation. Also I've seen blades that have a "knockout" for a larger arbor or the older diamond shape on the inside saw flange/washer, but the last one I saw (a couple of weeks ago) was a diamond masonry blade.
Try tapping on this inner washer, or better yet gooble your saw's model #.
/ Circular saw arbor problem #5
You might look for blades with 1" arbor and then use a 3/4" to 1" bushing. I had to do something similar to adapt a dado blade on a table saw once.
Yes, the inner spindle washer is removeable. I could easily take it off and grind the lap flange off of it.
Rob
Yes, that's a possibility. Would that be any better than just removing the lap flange on the spindle washer though and using the 5/8" blade?
/ Circular saw arbor problem #10
Rob
Sorry, I was thinking it but didn't say it....does the "washer" have a flat side or a 5/8 ?
2009 CHEVROLET C8500 CREW CAB FLATBED TRUCK (A59823)
2009 CHEVROLET...
2010 John Deere 568 Megawide Plus Round Hay Baler (A60462)
2010 John Deere...
Forklift (A56857)
Forklift (A56857)
MGY Shop Heater (A60463)
MGY Shop Heater...
Snap-On Southern Thunder Edition 24-drawer tool box (A61307)
Snap-On Southern...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A57192)
2008 INTERNATIONAL...
