Building Lake Corona
/ Building Lake Corona #703
I grew up on a lake in Northern Indiana and slept on the dock more than one night in my youth, if the bugs were not bad, and it was a hot night, it was a very enjoyable memory
/ Building Lake Corona #704
We had a camp and I did the same, dragging a lawn recliner out onto the dock to sleep.
/ Building Lake Corona #706
I am afraid that the likelihood is high, that you may lose a lot of the trees that the roots were disturbed, but I am sure you already understand that
Most of them will do fine. If I had to bet more will live than not based on the amount of root I got into and depth.
/ Building Lake Corona #708
You can tell better than us with only photo evidence.
If they do it won't be a huge loss. Regardless the dirt had to be moved for easy access around the pond. Hard to tell in the pic but the east side now has a level walk path at least 10ft wide. Will try to run some more video when the west side is finished up.
/ Building Lake Corona #710
That tracksteer is a great machine. I can't get over how much you accomplish with it.
/ Building Lake Corona #711
You obviously have a great work ethic and it really shows in what you have done in a relatively short time. Your project looks great to me.
/ Building Lake Corona #712
I was surprised how sensitive some trees are to root damage, nature seems to be able to throw its wrath at tree roots and they seem to accept the wrath, but they seem ( to me anyway) that they are much more sensitive to human damage.
/ Building Lake Corona #713
Trees can be fickle. I have driven over a few of my large tree's roots over the years, on numerous occasions with no damage. Two huge White Oaks are right on my driveway. Drive over one with it wet enough to leave ruts, and that tree is a gonner. Got two near the large pond needing to taken out now.
hugs, Brandi
/ Building Lake Corona #714
hugs, Brandi
Oaks are particularly susceptible to even very slight root damage.
/ Building Lake Corona #715
In the Texas Hill Country live oak trees must be very hardy. It's common for roots to grow out of the ground. It's also common for people to mow over the tops of those roots. The trees still continue to thrive for years.
/ Building Lake Corona #716
We have 9 or 10 varieties of Oaks here in Missouri. I've got at least half of them in my timber. They seem to be very tough.
Not sure how the mature trees will respond to the water level. I killed two walnut trees by raising my pond level to within a foot elevation of the ground at the tree. Put them about 15ft from shoreline. Died in 3 years.
Have a nice walk path large enough for a UTV or tractor all the way around the pond now.
2020-11-09_04-58-29
Set a a couple of logs. Top one for walking. Bottom one for fish.
2020-11-09_04-57-38
Bunched up some of the root balls and added a few stones for fish habitat
2020-11-09_04-57-27
This pic give a good idea of how much dirt has been moved. Still not happy with the dam slop on the water side. I can back up it with the trackloader but it's still very steep. A little worried about erosion if I don't slope it out some more. Will have to pull more dirt from the hillside between the two ravines.
2020-11-09_04-57-12
/ Building Lake Corona #719
It will only have erosion above waterline. Not sure where that's at?
If erosion occurs it will begin to narrow the top of the dam. How much of that can you stand?
Not sure by the pics how wide the top is now?
/ Building Lake Corona #720
Also, it will take many yards of dirt to change the slope of the front face. And if you change it very much you'll start to crowd your pipe inlet.
2016 FREIGHTLINER CL120 GLIDER 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
2016 Peterbilt 579 Automatic High Top Sleeper (69") (A62613)
2016 Peterbilt 579...
Linx EQ10020RS 20ft Trailer (A65640)
Linx EQ10020RS...
2018 GEHL RS5-19 GEN3 TELESCOPIC FORKLIFT (A65053)
2018 GEHL RS5-19...
Rotary 15,000lb. 4-Post Auto Lift (A64556)
Rotary 15,000lb...
2022 Power Screen Phoenix 3300 Tri-Axle Trommel Screener (A64194)
2022 Power Screen...
