How does an HST compare in pulling power with the same tractor and a gear trans?
   / How does an HST compare in pulling power with the same tractor and a gear trans? #21
Just look at professional tractor pullers. You need a level of spinning and digging to get down to the "good ground".
There’s a lot of difference in pulling tractors and regular tractors.
   / How does an HST compare in pulling power with the same tractor and a gear trans? #22
The only hydros I can put a direct correlation to would be the IH 656 gear and hydro and the IH Hydro 100 and a IH 986.
I ran all 4 of these in the same time frame the geared tractors would outpull the hydros any and every day of the week.
On light duty jobs or light road hauls (empty wagons) the hydros were faster.
For pto work the hydros were a touch better in that you could find the perfect gear for the pto horsepower.
For light duty the hydros were as nice or nicer.
When you made them work on drawbar loads the fuel economy of the hydros was terrible compared to the gear tractors.
For chopping corn pulling a chopper and wagon the hydo version was as good or better till you got 2/3s of a load or into soft ground were you needed the drawbar pull,
then the hydros would fall flat.
As far as tractor pulling even when new the hydros couldn't hold their own even in the stock classes.
Those examples may be a bit bigger then these new compacts but I'd believe the comparison to be valid.
   / How does an HST compare in pulling power with the same tractor and a gear trans? #23
My HST can scrub all 4 tires in low range (4 WD) and dig holes and bury its self..... My pulling power out does it weight factor to cause traction....
Whats to compare?
Dale
   / How does an HST compare in pulling power with the same tractor and a gear trans? #24
Point “A” to point “B” at one speed - geared tractor
Point “A” to point “B”, pick up a load of gravel, back up to point “C”, go to point “D” and start spreading the load between point “D” and “E” then back it up carefully between & around point “F” to park it at point “G” - HST tractor
   / How does an HST compare in pulling power with the same tractor and a gear trans? #25
I never heard it put like that, but it makes sense to me!..
   / How does an HST compare in pulling power with the same tractor and a gear trans? #26
I used a 33 HP NH and LS that are virtually the same.
I tested both in a mid range gear that put them at equal speed. The HST would bog down and stop when working up steep hills. The gear didn't even notice the hill and could almost idle up it.
They are both have the same max pull force in low range as they are traction limited, even on flat concrete.
HST will do the same work, just slower than gear.
I still bought HST since I don't have enough hands and feet to: steer, shift, brake, clutch, operate loader, change throttle while navigating my constantly changing terrain.
   / How does an HST compare in pulling power with the same tractor and a gear trans? #27
In one sense, HST uses HP.
I don't think the question is a very valid one. Too many apples to oranges comparison. Take the same tractor model, same tires and same application, and if available in both hydro and gear, you could probably make some valid comparisons. It would have to be unbiased, as often people just defend what they have.
You almost certainly have more control over your traction with an HST, but it has other disadvantages not related to traction.
   / How does an HST compare in pulling power with the same tractor and a gear trans? #28
I agree with this. I am afraid though we may never know. Kinda like how many licks to get to the center of a tootsie roll pop. :licking:
   / How does an HST compare in pulling power with the same tractor and a gear trans? #29
Depends on whether you "crunch" or not.... :)
   / How does an HST compare in pulling power with the same tractor and a gear trans? #30
The only hydros I can put a direct correlation to would be the IH 656 gear and hydro,
the same manufacture, the same frame, the same size rubber, both gas engines,
they were doing the same work on the same farm day in and day out for well over 20 years.
Then the hydro puked and the replacement hydro never worked right.
the geared tractors would out pull the hydros any and every day of the week.
I would say that those tractors were your apples to apples comparison.
I put a lot of hours on both of those tractors working them daily.
Also I believe that both of those models have Nebraska test data available if anyone cares to read up on them.
2014 KOMATSU HM400-3 OFF ROAD DUMP TRUCK (A60429)
2014 KOMATSU...
2016 CATERPILLAR 330FL EXCAVATOR (A60429)
2016 CATERPILLAR...
2006 KOMATSU PC228USLC-3 EXCAVATOR (A60429)
2006 KOMATSU...
2017 John Deere 1025R Tractor - 626 Engine Hours (A56438)
2017 John Deere...
Informational Lot - Financing (A56438)
Informational Lot...
2024 DEVELON DL250-7 WHEEL LOADER (A59823)
2024 DEVELON...
