Kubota Hazard Switch Plug ID
/ Kubota Hazard Switch Plug ID #1
rescue161
Member
Hubert, NC
LX2610SU
I bought a hazard switch to use for my emergency lighting for highway/bank use. I bought a factory hazard switch so I could use it in one of the blank cutouts on the dash. I am having a difficult time locating the plug that mates with this OEM switch. I pull out the factory PTO override to take a couple of pictures, so everyone could see what I need.
Here is the switch that I bought
kNSIe3ZZH-LXQj1DTXtGnBVO4KztA_w3gpim-P8YrBAmYdtxfI_fZ4L7pu-FhL64vKt1orEHsgwtUGaK13oqTCl0Fkk8U-cYp1TI0XrVWNy-B1lzbOhx-LHDIRduVa0y8nGTkGABHZtGHlFQ-e8lywhoiDXVcjkysB9NiW_PiQSkGyU9XkUlFvYeeCMcJIqk_XKVm0No1gW6mqThf0GvaVzpv5iIlCQf3DZWcZdnenK0Xq39Fm3-yDu3tMIDm-MUNhVKH44WS1MA3_MBes-btkIZE6WaSdPrk__76p0O7q1FkfqZXZSfd5P7a_8co4lD81u3zmHHyuF7-Fonz5rzaEQX9wz79oto3wqm5Nxg78CuxK5TZsTUGGc_8glZt5PdgjOG0IctJ9URPYwuZpOO1uLdCuZqRWCF8cIr93hKyhHOLua15CHumG8ig9EtQN6kB3tzJQjKuKfJrr6m33vl1SElNr3OS5OLeKG4V3HkXnlWnOg2LXkoz8Vczpn0VQ2BzclXwpi8JxAc3P_Q_uBxsVdowQC-nmDDQ5D81n7GTQo1q2EgdtP9jF81wq9fPvWyawgEB95FEdu8VppGtt-GM8juLIXmKw5YaPF-rU2IAC1C-dHD4S12zLcUN6feEDP2y077vJSuBc8r5V1UplVk_FNrGrdSISioPEzf6pt80D_lXyPj0UVD5w=s752-no
Rear of switch
ACtC-3eoiJG8TjQatO4KO-43v_uDhct-Mv6Uj1JjDaskpndurBYP03Lelhyi8l6m2B7fcfFAQU6ceUyErP6iH-EPN6FyV0bmNk3xsAkJuQAkCccMnXMBp4Lod675lzJVTJ7RNVPtM9CDtTw8RxCq24zTYzk=s752-no
Here is the plug that I need
ACtC-3fO1fsjDUrUcgBfIJuk-ypiztQS5RjuLnwz0A-XERT154FPnRls6xDsWAVxrgyrtk8GrZipyUdGOj7RMhRApeE8z49clz1--eL_xc_1EUaAYNLexj1Chl0IXxiqrY-IFSMuLRj5pZNoAvGSMDsFkmc=w564-h752-no
Another angle
ACtC-3cor8XtQlgtGSV4RWPzuES20BzIFIfQMNh1jCp-_eWOBSvtW9L7Z1p4F-1K0V51YnlcBcmRAa2vQQTvMNwI8S3Ptul2r-76BD-u9EakQDxOwZ0cR3qXDD4VDtdr_bQ0lgpq7PkJdu4zV4EiekZVtbY=w564-h752-no
It is a 6-position female plug, with the outer four connectors populated. If I could get a part number or a type, I could order the connectors and the housing on Mouser and crimp what I need. I just don't want to solder directly onto the switch and would like to make this look as close to factory as I can. Please let me know if the photos are not visible and I'll upload to this site directly.
Thanks in advance,
Scott
/ Kubota Hazard Switch Plug ID #2
Success!! I have searched for that connector for a long time and just found it. The connector is a Sumatomi nonsealed MT 090 series PN 6242-5061. Link to Sumatomi catalog . You can buy the connector at Eastern Beaver. It is listed as the 6P090-MT SPA Female for $2.03. Extra pins also available on that page. I think he has a $5 or $10 minimum, so find something else to buy as well.
You are AWESOME and I owe you a beer or beverage of your choice! Thank you very much. I spent an unhealthy amount of time looking for it and kept turning up nothing. I just ordered a few. Thank you again.
Scott
/ Kubota Hazard Switch Plug ID #4
I spent an unhealthy amount of time looking it
I picked up a Kubota work light switch on eBay about 6 years ago. Been looking for that connector ever since. Very very unhealthy amounts of time. I stumbled across it last night while picking up some other connectors at Eastern Beaver. Motorcycle sites for Japanese bikes are a good place to pick up OEM electrical stuff for small Kubota tractors. Glad I could help.
I already installed one switch. I used four 7/64" female disconnects that I found at the local auto parts store (O'Reilly's). I made the harness with the four connectors and plugged them into the switch. I then wrapped electrical tape a few times around the connectors and then placed 3/8" loom over them and then continued the electrical tape. The body of the switch was still exposed to allow me to run a 4" zip-tie through the locking tab of the switch. Then I placed another 4" zip-tie around the loom and looped the switches' zip-tie around it and tightened both. The 7/64" connectors were very tight on their own and they are insulated from each other. That, coupled with the tape and zip-ties, pretty much guaranteed that the wires would never come loose. I'm just glad that I don't have to do the whole song and dance again. While I was on that site, I bought some crimpers (Hozan P-707). My old ones crimp, but they are too wide and distort smaller pins, so hopefully the new ones will work great and I can retire the old pair.
/ Kubota Hazard Switch Plug ID #6
I have looked for connectors, without luck, but gave up in less than 6 years. Kudos to your patience and finding the connector!
2020 CATERPILLAR 279D3 SKID STEER (A62129)
2020 CATERPILLAR...
2021 ASV 75HD Skid Steer (A64047)
2021 ASV 75HD Skid...
PROPANE TANK CAGE (A62131)
PROPANE TANK CAGE...
STORAGE FEES (A59910)
JOHN DEERE 750 GRAIN DRILL (A58216)
JOHN DEERE 750...
LOOK! (A63109)
LOOK! (A63109)
