Kubota Hazard Switch Plug ID
/ Kubota Hazard Switch Plug ID #1
rescue161
Member
Hubert, NC
LX2610SU
I bought a hazard switch to use for my emergency lighting for highway/bank use. I bought a factory hazard switch so I could use it in one of the blank cutouts on the dash. I am having a difficult time locating the plug that mates with this OEM switch. I pull out the factory PTO override to take a couple of pictures, so everyone could see what I need.
Here is the switch that I bought
kNSIe3ZZH-LXQj1DTXtGnBVO4KztA_w3gpim-P8YrBAmYdtxfI_fZ4L7pu-FhL64vKt1orEHsgwtUGaK13oqTCl0Fkk8U-cYp1TI0XrVWNy-B1lzbOhx-LHDIRduVa0y8nGTkGABHZtGHlFQ-e8lywhoiDXVcjkysB9NiW_PiQSkGyU9XkUlFvYeeCMcJIqk_XKVm0No1gW6mqThf0GvaVzpv5iIlCQf3DZWcZdnenK0Xq39Fm3-yDu3tMIDm-MUNhVKH44WS1MA3_MBes-btkIZE6WaSdPrk__76p0O7q1FkfqZXZSfd5P7a_8co4lD81u3zmHHyuF7-Fonz5rzaEQX9wz79oto3wqm5Nxg78CuxK5TZsTUGGc_8glZt5PdgjOG0IctJ9URPYwuZpOO1uLdCuZqRWCF8cIr93hKyhHOLua15CHumG8ig9EtQN6kB3tzJQjKuKfJrr6m33vl1SElNr3OS5OLeKG4V3HkXnlWnOg2LXkoz8Vczpn0VQ2BzclXwpi8JxAc3P_Q_uBxsVdowQC-nmDDQ5D81n7GTQo1q2EgdtP9jF81wq9fPvWyawgEB95FEdu8VppGtt-GM8juLIXmKw5YaPF-rU2IAC1C-dHD4S12zLcUN6feEDP2y077vJSuBc8r5V1UplVk_FNrGrdSISioPEzf6pt80D_lXyPj0UVD5w=s752-no
Rear of switch
ACtC-3eoiJG8TjQatO4KO-43v_uDhct-Mv6Uj1JjDaskpndurBYP03Lelhyi8l6m2B7fcfFAQU6ceUyErP6iH-EPN6FyV0bmNk3xsAkJuQAkCccMnXMBp4Lod675lzJVTJ7RNVPtM9CDtTw8RxCq24zTYzk=s752-no
Here is the plug that I need
ACtC-3fO1fsjDUrUcgBfIJuk-ypiztQS5RjuLnwz0A-XERT154FPnRls6xDsWAVxrgyrtk8GrZipyUdGOj7RMhRApeE8z49clz1--eL_xc_1EUaAYNLexj1Chl0IXxiqrY-IFSMuLRj5pZNoAvGSMDsFkmc=w564-h752-no
Another angle
ACtC-3cor8XtQlgtGSV4RWPzuES20BzIFIfQMNh1jCp-_eWOBSvtW9L7Z1p4F-1K0V51YnlcBcmRAa2vQQTvMNwI8S3Ptul2r-76BD-u9EakQDxOwZ0cR3qXDD4VDtdr_bQ0lgpq7PkJdu4zV4EiekZVtbY=w564-h752-no
It is a 6-position female plug, with the outer four connectors populated. If I could get a part number or a type, I could order the connectors and the housing on Mouser and crimp what I need. I just don't want to solder directly onto the switch and would like to make this look as close to factory as I can. Please let me know if the photos are not visible and I'll upload to this site directly.
Thanks in advance,
Scott
/ Kubota Hazard Switch Plug ID #2
Success!! I have searched for that connector for a long time and just found it. The connector is a Sumatomi nonsealed MT 090 series PN 6242-5061. Link to Sumatomi catalog . You can buy the connector at Eastern Beaver. It is listed as the 6P090-MT SPA Female for $2.03. Extra pins also available on that page. I think he has a $5 or $10 minimum, so find something else to buy as well.
You are AWESOME and I owe you a beer or beverage of your choice! Thank you very much. I spent an unhealthy amount of time looking for it and kept turning up nothing. I just ordered a few. Thank you again.
Scott
/ Kubota Hazard Switch Plug ID #4
I spent an unhealthy amount of time looking it
I picked up a Kubota work light switch on eBay about 6 years ago. Been looking for that connector ever since. Very very unhealthy amounts of time. I stumbled across it last night while picking up some other connectors at Eastern Beaver. Motorcycle sites for Japanese bikes are a good place to pick up OEM electrical stuff for small Kubota tractors. Glad I could help.
I already installed one switch. I used four 7/64" female disconnects that I found at the local auto parts store (O'Reilly's). I made the harness with the four connectors and plugged them into the switch. I then wrapped electrical tape a few times around the connectors and then placed 3/8" loom over them and then continued the electrical tape. The body of the switch was still exposed to allow me to run a 4" zip-tie through the locking tab of the switch. Then I placed another 4" zip-tie around the loom and looped the switches' zip-tie around it and tightened both. The 7/64" connectors were very tight on their own and they are insulated from each other. That, coupled with the tape and zip-ties, pretty much guaranteed that the wires would never come loose. I'm just glad that I don't have to do the whole song and dance again. While I was on that site, I bought some crimpers (Hozan P-707). My old ones crimp, but they are too wide and distort smaller pins, so hopefully the new ones will work great and I can retire the old pair.
/ Kubota Hazard Switch Plug ID #6
I have looked for connectors, without luck, but gave up in less than 6 years. Kudos to your patience and finding the connector!
John Deere 7230 (A62180)
John Deere 7230...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A62131)
UNUSED WOLVERINE...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
2020 John Deere R4045 Sprayer (A63109)
2020 John Deere...
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
2009 BMW Sedan (A61569)
2009 BMW Sedan...
