Snow Attachments Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #11
Lots of good advice above. Especially about understanding your snow conditions. One size does not fit all.
I saw the dealer mount the front blower on the same tractor I was buying (much larger than yours) and that killed a front blower for me. But I am 70 and do not want to crawl around on my back in the cold. The other issue was where to store the frame when I was not using it. Cost was a factor as well. Lastly, was ease of mounting pallet forks to move totes of firewood.
Like Hillbilly I use a front blade (my rear blade mounted on a 3PH to SSQA adapter) and an inverted blower. I have no large drifts or mountains of snow to blow so the inverted blower works well.
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #12
I guess the question is? Who likes backing anything up?
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #13
Only an idiot...or cheapskate LOL
The front blower was $7000 for my LS. A pull blower was $4000. The front blower has its own set of deficiencies.
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #14
I guess that makes me an idiot due to not minding backing about anything up.
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #15
Definitely have to agree with shooterdon,
Front aren't always all they are cracked up to be, cost, efficiency, loss of loader, clouds of powder obscuring view.
I think he has the best combo- Front blade back pull
Of course the rear pull isn't always the best either.
I think i would do a front blade rear push as my second choice.
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #16
Yep... they surely aren't cheap. The Front Blower for my B3000 was $6K.
But that's only a fraction of what back surgery costs..... :.)
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #17
I guess you might then ask. How far do you have to back up? A hundred yards or a mile?
Having said that, an old guy having to turn his neck, is not a bad thing. Use it or loose it as they say.
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #18
I will take driving backwards for 45 minutes in a nice warm cab on a bigger machine vs 3 hours on SCUT driving forwards freezing and wet any day.
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #19
I have used a hydraulic front blower for 9 years. After 14 years of backing up moving north idaho snow my neck had enough. But i have a 45hp cab tractor. Mine works like a charm unless snow is really wet, which can happen. Then i swap out to the plow. Only takes me a few minutes. My blower is a quick connect after removing bucket, then plug in 2 hoses and 1- 7pin auto style plug. Was not cheap....about 10 grand. Worth every penny. 9 years of use, never failed me. I can move snow pile thats 8 feet high
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #20
When I bought my Kioti I also bought the front mount blower for it. ($8,000.oo)
I found that heavy wet snow and snow blowers do NOT get along. They plug up and I found that I spent more time clearing chute obstructions than actually blowing snow. I haven't used my front mount for three years and have no intentions of using it this year. In fact it is for sale the first 4 grand takes it AND the harness and drive shaft away. A bucket is better IMHO, because IF you get stuck you can pry yourself out with the bucket. You can't do that with the blower on the front.
Kubota SVL 97-2 (A53317)
Kubota SVL 97-2...
1" Pneumatic Impact Wrench (A59076)
1" Pneumatic...
2017 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
2015 Ford Explorer XLT 4X4 SUV (A56859)
2015 Ford Explorer...
2014 PETERBILT 388 VACUUM TRUCK (A55745)
2014 PETERBILT 388...
Terms & Conditions of (Buying through EquipmentDealz Auction) (A59213)
Terms & Conditions...
