Snow Attachments Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #11
Lots of good advice above. Especially about understanding your snow conditions. One size does not fit all.
I saw the dealer mount the front blower on the same tractor I was buying (much larger than yours) and that killed a front blower for me. But I am 70 and do not want to crawl around on my back in the cold. The other issue was where to store the frame when I was not using it. Cost was a factor as well. Lastly, was ease of mounting pallet forks to move totes of firewood.
Like Hillbilly I use a front blade (my rear blade mounted on a 3PH to SSQA adapter) and an inverted blower. I have no large drifts or mountains of snow to blow so the inverted blower works well.
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #12
I guess the question is? Who likes backing anything up?
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #13
Only an idiot...or cheapskate LOL
The front blower was $7000 for my LS. A pull blower was $4000. The front blower has its own set of deficiencies.
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #14
I guess that makes me an idiot due to not minding backing about anything up.
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #15
Definitely have to agree with shooterdon,
Front aren't always all they are cracked up to be, cost, efficiency, loss of loader, clouds of powder obscuring view.
I think he has the best combo- Front blade back pull
Of course the rear pull isn't always the best either.
I think i would do a front blade rear push as my second choice.
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #16
Yep... they surely aren't cheap. The Front Blower for my B3000 was $6K.
But that's only a fraction of what back surgery costs..... :.)
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #17
I guess you might then ask. How far do you have to back up? A hundred yards or a mile?
Having said that, an old guy having to turn his neck, is not a bad thing. Use it or loose it as they say.
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #18
I will take driving backwards for 45 minutes in a nice warm cab on a bigger machine vs 3 hours on SCUT driving forwards freezing and wet any day.
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #19
I have used a hydraulic front blower for 9 years. After 14 years of backing up moving north idaho snow my neck had enough. But i have a 45hp cab tractor. Mine works like a charm unless snow is really wet, which can happen. Then i swap out to the plow. Only takes me a few minutes. My blower is a quick connect after removing bucket, then plug in 2 hoses and 1- 7pin auto style plug. Was not cheap....about 10 grand. Worth every penny. 9 years of use, never failed me. I can move snow pile thats 8 feet high
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #20
When I bought my Kioti I also bought the front mount blower for it. ($8,000.oo)
I found that heavy wet snow and snow blowers do NOT get along. They plug up and I found that I spent more time clearing chute obstructions than actually blowing snow. I haven't used my front mount for three years and have no intentions of using it this year. In fact it is for sale the first 4 grand takes it AND the harness and drive shaft away. A bucket is better IMHO, because IF you get stuck you can pry yourself out with the bucket. You can't do that with the blower on the front.
(2) SPRINKLERS & HI-RISE STANDS (A58374)
(2) SPRINKLERS &...
2002 Frieghtliner Pressure Digger Truck (A55973)
2002 Frieghtliner...
2018 John Deere 30G Mini Excavator (A56857)
2018 John Deere...
Year: 2007 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2007 Make...
CENTURY 1000 GALLON SPRAYER (A52708)
CENTURY 1000...
Enerpac Hushh-Pup Hydraulic Power Unit, Model Per-132, Product Code B14880, 1/3 HP, 120 Volts, 1 (A59076)
Enerpac Hushh-Pup...
