MF 1010 electrical help? No Start mystery
   / MF 1010 electrical help? No Start mystery
thanks.
What do the bolts look like? With the starter wiggling do I already have the threads backed out enough to tap the starter away or do I have to keep turning?
I'm working blind here so your help is appreciated
   / MF 1010 electrical help? No Start mystery #22
thanks.
There are just two long bolts. (Didn’t measure but maybe 5 inches long?)
In the photo you can see how the grime outlines the flange of the starter. I have removed the lower bolt in this picture and you can see the threads of the upper bolt.
These bolts extend all the way through to where the brake pedal is. So you will need to hold the head of the bolt while you unscrew the nut. Tap the lower bolt out after you have removed the nut. Use a hammer and a piece of wood to protect the bolt. Once that bolt is free, the starter will come out easily.
   / MF 1010 electrical help? No Start mystery #23
Here’s a pic of the new starter.
   / MF 1010 electrical help? No Start mystery #25
turns out hot/lead positive terminal was bad, starter wiring also stuck on draining battery further.
Started up and runs fine.
Still cant get the lights to work
If I dont get back on the thread, thanks to all for the inputs.help
   / MF 1010 electrical help? No Start mystery #27
Well I will be darned!
Now, tell me about the lights again. I love a good (electrical) mystery!
Should be easy, simple circuit off the fuse box, tomorrw
Went to start it today, slow whirring noises and smoke/heat from the starter.
Fan turning slowly.
Did my new starter go bad already?
checked all connections, charging the battery.
Turning over no start
Starter getting hot
J & M 1150 Grain Cart (A50514)
J & M 1150 Grain...
2017 KOMATSU PC228USLC-10 EXCAVATOR (A51242)
2017 KOMATSU...
2004 Capacity Yard Spotter Truck - Cummins Diesel, Allison Auto, Low Hours (A52128)
2004 Capacity Yard...
30' Harvest Hand Head Cart (A50514)
30' Harvest Hand...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A52128)
NEW 2025 Load...
2015 FORD F750 BOX TRUCK (A51219)
2015 FORD F750 BOX...
