Loader Chain Grab Hooks
/ Chain Grab Hooks #21
I don't seem to share the enthusiasm some have for hooks, bolt on or weld on. I prefer the slotted angle iron so chains will hook into it from the front or back of the bucket and it adds strength to the top of the bucket. Mine is welded on but I suppose a person could bolt it on also.
/ Chain Grab Hooks #22
Another positive for slots...
Dale
/ Chain Grab Hooks #23
And another vote for chain slots blue TU.gif.
Chain slots on the fork frame:
Chain slots on the brush fork frame:
/ Chain Grab Hooks #26
Hmmmm,I'm thinking there's room for a new line of products. Dale's Slots and Rings. I'm especialy fond of the one that can accomindate various attachments by simply pulling a pin. :drink:
/ Chain Grab Hooks #27
One could always make a simple ring with a "T" bracket on it to drop in slot if you needed a loop....
I was frustrated that I wanted to have a couple of rings for running chain through and most of the hardware store loops/links just did no fit the bill.... So I made them, 1/2 stock wrapped around 3 inch O.D. pipe, overlapped and welded... Angle iron in picture is bolted to front crossmember of tractor frame .... Also have same shackle and ring arrangement on rear chassis draw bar... Both were put in place so I don't have to pull on FEL or 3PH for some serious yanking...
Had thought of putting receiver hitch on angle instead of shackle because there is all sorts of "tools" that plug in to receivers today...
You adapted to fit your needs not just always by what you can buy....
Dale
/ Chain Grab Hooks #28
You adapted to fit your needs not just always by what you can buy....Dale
So am I to believe today's store bought gas cans don't fit your needs either? :laughing:
/ Chain Grab Hooks #29
I have found the receiver hitch on the tractor bucket most handy. Not only for various hooks and loops but other attachments.
Pintle trailer hitch for moving and dumping army trailer on the farm. Ball hitch for smaller trailers and log splitter.
Bale spear for round bales.
Vise mount. Has saved trips back to shop for repairing water lines. Some equipment repairs hard to bring into shop.
Barb wire roll reel.
Shop crane. Sometimes need precision lift/placement for repairs.
Platform carrier for 12v sprayer. Can see level and securely strap down poly sprayer.
Working on hydraulic polesaw. Reinforced receiver hitch welded to brush grapple frame.
/ Chain Grab Hooks #30
Yep, I put a receiver hitch on the brush fork frame:
/ Chain Grab Hooks #31
I got Ken's hook/clevis combo with the backing plate. Ropes, chains, straps all work fine.
I will say there are a lot of great ideas in this thread, and some amazing DIY setups.
2022 YANMAR VIO80-1A EXCAVATOR (A63276)
2022 YANMAR...
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2008 Ford F-250...
2024 BOBCAT S76 R-SERIES SKID STEER (A64279)
2024 BOBCAT S76...
UNUSED PARBREAK GCC56 2 PRONG BALE SPEAR (A65055)
UNUSED PARBREAK...
JOHN DEERE QUICK ATTACH PALLET FORKS (A64278)
JOHN DEERE QUICK...
2016 Ford Escape AWD SUV (A64557)
2016 Ford Escape...
