CK 2610 Starting Issue
/ CK 2610 Starting Issue #1
MikeR 2018
Central Pa
Kioti CK2610 HST with FEL, Rotary Cutter, Box Blade and HLA Grapple
I have a CK2610 with about 220 hours. It has difficulty starting it if it has been idle for a day or more. I run the glow plug and crank the engine. It starts and runs for about 30 seconds, then looses rpm and dies. I wait 10 seconds and try again - it usually starts and keeps running then, but the first 10 seconds it runs very sluggish, then the RPMs come back up and everything seems ok.
Sometimes it takes two tries.
It is not due to a cold start. I have tried it after the engine has completely cooled - 8 hours or so, and it starts right up. It only happens if it has been sitting for one or more days.
I am afraid that this is going to get worse and one time will not run at all. Any ideas?
/ CK 2610 Starting Issue #2
Sounds like fuel delivery to me. Thanks for coming to my TED talk! But yeah could be number of issues pertaining to fuel delivery.
/ CK 2610 Starting Issue #3
It does sound like a fuel thing. Perhaps you have one or more loose delivery lines to injectors allowing fuel to bleed back out. Maybe you have injectors not closing completely. Perhaps your fuel filter is a bit loose. Regardless, it sounds as though you're losing prime somewhere and having to pump fuel back into the lines. You could try cranking without the glow plugs to prime it. Then light the glow plugs and see if it's any better.
I'll give that a try. Thanks
/ CK 2610 Starting Issue #5
It sounds like a fuel "prime" problem but here's something quick to try. I think your 2610 has mechanical (vs computer) fuel injection. If so, but try a couple shots shot of WD40 in the key hole (and cycle the key a few times). The stop solenoid "hold" coil must be powered continuously (directly from the key switch) or the engine stops. Dirt or corrosion on that contact in the switch could cause your problem. The restart (or recent start) might wipe the contact to clean them temporarily.
I ll give that a try but I don't think thats it. The engine does not suddenly stop. The RPMs decrease until the engine dies, like it is being starved of fuel. On the restart, the RPMs are sluggish and gradually pick up until it runs normally. The exhaust also smokes like crazy until it warms up.
/ CK 2610 Starting Issue #7
Agree. A switch/stop solenoid problem would cause a sudden stop, like shutting off the key.
/ CK 2610 Starting Issue #8
I've never seen a Kioti so bear with me. Does it have a lift pump - a kind of pre pump to feed the injection pump? If it does that could be the issue - unlikely as they last "forever" but it could have an issue. They are a gear type pump and may have to get up to speed to feed fuel smoothly to the injection pump. Of course many small tractors are gravity fed and have no lift pump. It was a thought.
Don't know. I'll have to check.
/ CK 2610 Starting Issue #10
Wondering if you致e found a solution to this problem. My CK2610 just hit 200 hours and is having the same problems. If I decrease throttle quickly it stumbles and dies. Then just cranks and won稚 restart. I figured it was a fuel prime issue so I pump the manual primer on top of the filter housing but no luck. I notice if I twist the key backwards almost to activate the glow plugs it will generally start and then run fine until I decrease throttle again. Weird thing is, it does not light the glow plug indicator light like I remembering it doing when I use them in the winter for cold starts. Wondering if anyone has any input before I reach out to the dealer.
/ CK 2610 Starting Issue #11
This. I had a similar problem on my work truck. Had to get a couple tows because there truck would slowly quit from no fuel and wouldn't start. Long story short, when I was using the fuel primer I heard some hissing from a couple fittings of the fuel system. I pointed them out to our 'mechanics.' They tightened them, low and behold I didn't have that problem again.
Good luck.
Just to add an update. I noticed that it's not as bad if the fuel tank is full, which leads me to believe that is is a vacuum leak. Now, recently the symptom has gone away. I don't know why.
/ CK 2610 Starting Issue #13
I will add an update also. Changed all fluids and filters at 200 hours. Problem has since gone away. Not sure if fuel filter was restricting flow or ???? but no issues now.
/ CK 2610 Starting Issue #14
I wonder if the fuel filter wasn't right and was just letting just enough air in to lose prime.
/ CK 2610 Starting Issue #15
That's good to know. My CK 2610 is doing the same thing. Ordered all new filters and will see how that goes.
How hard was your tractor to prime after filter replacement? Last time I changed, it took forever to prime and start again.
/ CK 2610 Starting Issue #16
If you fill the filter prior to installing you should have no issues - my Kubota. JD and now the Kioti all fired right up after the filter exchange, I filled them, If they had a primer I'd hit it once or twice turn the key and they fired -
/ CK 2610 Starting Issue #17
I had the exact same problem with my 2610. Filled the filter before installing, primed using the pump etc. the owner’s manual is not much help unlike older tractor manuals.
There is a valve on top if the filter assembly that is a screw in valve. Open the valve a couple of turns, then pump the primer until diesel comes out around the valve. Then close the valve tight by turning it clockwise.
After I did this (after researching it on you tube), it has started first time, every time, no stalls no loss of power.
/ CK 2610 Starting Issue #18
I'll give that a try. I opened that valve the other day and pumped it. Just air came in and out. I'll try to pump it till fuel comes out and see if that fixes my issue.
1995 Jeep Wrangle 4x4 Soft Top (A62613)
1995 Jeep Wrangle...
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
BUNDLE OF APRROX (20) 3'X30' METAL SHEETS (A62131)
BUNDLE OF APRROX...
23" QUICK ATTACH EXCAVATOR BUCKET (A60429)
23" QUICK ATTACH...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
UNUSED SDLANCH REMOTE CONTROLLED BULLDOZER (A62130)
UNUSED SDLANCH...
