Grapple Help
   / Grapple Help #12
My assumption is that the cheaper units use a lower quality steel, and to get adequate strength they need to be heavier. My MTL was cheap ($1000) and heavy but I have plenty of FEL capacity.
If I had the funds, I would have purchased an EA grapple. I move 10-20 cords of logs a year and could not justify it. Additionally, at 70 YO, I will not be doing this for too much longer.
   / Grapple Help
Yeah the MTL uses A36 steel at 3/8". The Falcon is 1/4" grade 50 which is stronger and lighter but probably comparable to the 3/8" A36. I'm only 40 and do about 3 cords a year plus any property cleanup but want something that will holdup. I only have around 1200 lbs lift at the pins so need to keep it light weight.
   / Grapple Help #14
Most of my "property cleanup" is cutting trees and branches. For branch piles, it helps if your grapple has the ability to grab a big arm full of debris. We make neat piles by hand as we are cutting trees so when we burn the next brush pile, I can keep feeding it with the grapple. If we have a wind or ice storm, I may have 40 big grapple piles to feed the fire. It has been the best work-saver attachment I have. Mine is a Bobcat general purpose bucket with the Bobcat grapple attachment. It is not the best design for any one job but it does work good for a variety of different jobs. I have thought of cutting back the sides of the bucket to give it more room for logs but so far it is fine. If I had a sawzall close by, I would have cut it.:dance1:
   / Grapple Help #15
Log Weight Calculator at WOODWEB
You are not handling much wood so think about your needs. The above calculator can help.
In my case, I used my heaviest wood (oak) to look at weight requirements. My firewood logs are 14" or less in diameter, and 100" long. If you need to clean up a large tree that has fallen, you can cut it to manageable lengths for firewood processing, so getting a heavier grapple may not be a bad trade off. If you are going to use the logs for lumber, cutting up to shorter lengths is not an attractive option.
Compact Tractor 48"-54"-6" HD Root Grapple Hydraulic - quick attach — MTL Attachments
This is a smaller version (48") of the 60" MTL I have and weighs 350 lbs. Seems it would be a good fit and likely handle 98% of your needs. Only you know how often you will need to move logs heavier than 750 lbs.
   / Grapple Help #17
   / Grapple Help
I think I'm going with the 48" MTL. Now donibuse the WRLong 3rd function or the Landpride? Or should I go with a diverter?
   / Grapple Help #19
For your uses, I'd go with a diverter and put it out on the FEL frame crossbar just behind the Grapple.
   / Grapple Help #20
Coltbean,
I have a NIB diverter valve I bought when I was going to put a bolt on grapple on my JD 855 if you decide to go that way. Email me if you are interested.
When I got the LS, I had the dealer add a 3rd function. Glad I went that way. If you will be using the grapple much it is a nice set up. The LS will be my last tractor so that is why I made the investment.
If you will be keeping your machine for a long time, go with the 3rd function if you can afford it.
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
MASSAGE CHAIR (A58214)
Gehl 125 Mix-All Feed Mixer (A56469)
Gehl 125 Mix-All...
2011 Chevrolet Impala Sedan (A55853)
2011 Chevrolet...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2016 Peterbilt 320...
2018 John Deere 30G Mini Excavator (A56857)
2018 John Deere...
