John Deere 4020 Powershift Transmission
/ John Deere 4020 Powershift Transmission #1
Swamp Monster 33
John Deere 6200
Hi Folks-
I have a John Deere 570A motorgrader that supposedly shares the same powershift transmission with the 4020, less the PTO.
Anyway, all forward gears are working properly, but reverse has quit; no backing up.
I was wondering if anybody had any ideas about that, and also if anybody can point me to any overhaul information.
Thanks much.
/ John Deere 4020 Powershift Transmission #2
I would look closely at the linkage. I have no experience with a 570A.
The 4020 is my all time favorite tractor but the one I ran did not have the power shift transmission but hopefully someone else will have some good thoughts. Good luck!
Thanks. The linkage is the first thing on my list. Much appreciated.
/ John Deere 4020 Powershift Transmission #4
Welcome to TBN
I agree on checking shift linkage & possible shift valve on lower RH side of clutch housing. 1-2-3-4 F & R utilize same trans components. My 1st guess is direction control cable failure which controls F/R in shift valve.
Thanks TX Jim- That's going to be first on my list today. Thanks again.
/ John Deere 4020 Powershift Transmission #6
You're welcome.
Tx Jim- Well; I carefully checked the Forward/Reverse linkage. I found a worn clevis that had a little play in it and hoped that it was the problem. Nope. Disconnected the Linkage at the trans and physically moved it into the reverse position. Nope again. Ran pressures on the the trans: got 150 psi in forward but only 50 in reverse. With the drive wheels raised and the trans in reverse the wheels actually move in reverse. Wheels on the ground, they try to move, but no.
/ John Deere 4020 Powershift Transmission #8
I can't speak to your specific transmission, but I have a 410 backhoe that probably uses a similar transmission design.
A known issue with the 410 transmission is o-ring failure on the clutch packs. If you're seeing 130-160 psi on the supply side, your o-rings are ok. If you're seeing less then 100 psi, your o-rings are shot and your clutch packs are slipping.
In the 410, the forward clutch packs are accessible from the front of the reverser, so you just have to pull the engine. The reverse pack are in the back and you have to pull the entire unit to get access to them. Might be the same deal with your transmission.
Thanks. Much appreciated.
/ John Deere 4020 Powershift Transmission #10
Thanks much. I'm a member over there. Thanks again.
/ John Deere 4020 Powershift Transmission #12
I agree with Jason with only 50 psi pressure in reverse it sounds as if reverse drum seal is leaking internally
Thanks much. Tx Jim.
2019 CATERPILLAR 316FL EXCAVATOR (A65053)
2019 CATERPILLAR...
John Deere 148 Loader with Brackets (A65640)
John Deere 148...
John Deere 18ft. 3 Point Field Cultivator (A65640)
John Deere 18ft. 3...
(16) Kinze 3000 Precision Plant Corn Meters (A65640)
(16) Kinze 3000...
NEW Wolverine SP-15-84W Snow Blade (A62679)
NEW Wolverine...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
