Loader broken FEL arm to bucket attachment pin
/ broken FEL arm to bucket attachment pin #1
kw22614
Manassas, VA
Kubota BX1860
What's that pin called? it attaches the FEL side arm to the bucket. Mine is about 3/4" diameter & 4&1/2" long.
Broke one today moving HEAVY chunks of logs to the splitter.
Can't find any listing anywhere so I assume I'm not calling it by it's proper name.
Just started my firewood processing and still have lots to go, I need my loader to work....
You DA MAN, moship!
That's exactly right, both - I have a LA 203 and the correct part & #.
I just found it 5 mins ago myself.
Back to firewood soon.
CHEERS!
/ broken FEL arm to bucket attachment pin #4
Did you figure out why it broke? Did anything else twist as I suspect the bucket would have dropped and twisted the other side pin, the loader opposite arm or bottomed the failed side bucket cylinder against the failed side arm?
Thanks for your concern repete.
Can't find any other damage or twists or anything (so far). The right side pin that broke, only half of it fell out so that connection was still mostly together, and didn't seem to cause any racking or subsequent damage (at least not yet).
My dealer didn't have any replacement pins in stock, but I called another dealer about 45 mins away and they have 1 left. Will go get it soon. Only a $7 part.
When I change out to the new one I'll post a couple pics.
My fault it happened, overloading weight & capacity limits and under greasing!
Lesson learned - at very least, keep those joints well greased!!!
/ broken FEL arm to bucket attachment pin #6
Glad it stayed in position for you. I had visions of it being elevated and the bucket tilted forward and letting go.
/ broken FEL arm to bucket attachment pin #7
Glad to hear it's a simple and inexpensive fix.
IMG_20201002_170115802.jpgIMG_20201002_170106719.jpgIMG_20201002_165437818.jpgIMG_20201002_102416195.jpgIMG_20201002_102403605.jpg
Thanx moship & repete for the time and effort you spent to help me!!
Have a happy happy, KW
PORTA COOL 2000 PORTABLE EVAPORATIVE COOLER (A59823)
PORTA COOL 2000...
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
2004 Winnebago Adventurer 38G 38ft. Class A Motorhome (A59231)
2004 Winnebago...
2015 Kubota L4701 (A60462)
2015 Kubota L4701...
2005 Sterling Acterra Tender Truck (A61307)
2005 Sterling...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A61307)
2022 Greenworks...
