3-Point Hitch Top link mount tore off back of differential case
   / Top link mount tore off back of differential case
Will do Richard.
   / Top link mount tore off back of differential case #22
   / Top link mount tore off back of differential case #23
Is there any chance of your home owners insurance helping? Might be worth an inquiry.
   / Top link mount tore off back of differential case #24
Good idea. My home owners policy replaced my Kubota B2910 that burned in my shop fire. It's function was maintenance of the property, so was covered. Would certainly be worth a call.
   / Top link mount tore off back of differential case #25
That stinks. :(
I've seen an L275 which had been broken worse than that and welded back together. His was torn a lot lower though, not around the bolt holes. I'm sure that it still had to be torn apart, in which case it might be easier to replace anyways.
   / Top link mount tore off back of differential case #26
Yeah. Welding it would require complete disassembly and reassembly of the trans case. Might be able to weld the 3pt case intact.
   / Top link mount tore off back of differential case #27
I inquired about a 5' brush cutter for my B2650. The salesman said he recommended a 4'. I told him I wasn't worried about the power requirements. He responded that he wasn't worried about the power, he was worried about breaking the top link mount. I thought it curious at the time.
   / Top link mount tore off back of differential case #28
Ouch. Makes me cringe. Good luck getting it fixed. A couple things I notice. I think this is beyond a weld repair. Can it be done? Most likely. Will it hold, depends on loading. Will you ever feel comfortable with running it at load? I would always be worried when I'd hit something with a shank or a mower that would stress the welded area and cause it to break. I'll also say that this does not look like a great casting to me. I see some thin wall sections like around the right side middle area. The way the bolt hole flange cracked and broke is crazy. And it looks like there was a crack along the lower surface that shows fatigue before fracture. Amazing what the new cameras can reveal with just a photo. If the dealer added the hoe for you, I'd certainly lean hard on them for free labor if not entire repair costs. If they didn't add the hoe, I would still try to ask the manufacturer to assist. However, that could be a long drawn out process. They are notoriously slow in response to these sorts of things and would likely attempt justify "no fault" due to the hoe. But worth a shot IMHO. Sometimes too the dealer will show mercy and make you pay for parts while they "absorb" the labor on a warranty claim.
It seems that the grain size on that casing is fairly large too......out of spec...doubtful. But for cast steel/iron in todays world, seems fairly granular. Assuming it's not Aluminum as I see some corrosion.
   / Top link mount tore off back of differential case #29
It sure makes it easy to inspect the diff-lock parts and their operation! Sorry for the OP and his broken tractor. Was the OP planning on using it for snow removal and does he have a good dealer/shop near by?
Couple of answers:
-Insurance: No way, not a covered peril (e.g. fire, lightening etc). I inquired
-Weld: Perhaps but I will never be able to attach anything to the top mount again.
-Estimates: They are all over the place.
   / Top link mount tore off back of differential case #31
cant see a backhoe on any compact tractor. 3 point or frame mount. Have read about multiple axle housings broken from a frame mount. 3 point a accident waiting to happen. its why a real backhoe is so darn big and heavy duty.
hopefully this helps someone else.
   / Top link mount tore off back of differential case #32
Sorry to see this... long time ago I bought a heavy duty top link, for a backhoe that I finally gave away (way too big). I left the HD toplink there just for the heck of it.
{EDIT} WOW, THERE IS NOT EVEN ANY PAINT RUBBED OFF THAT BUCKET... TEETH LOOK BRAND NEW....
More thoughts, that top link transfer all pressure, did you hit or bottom out the bucket when you were driving??
   / Top link mount tore off back of differential case #33
This is the sort of thing that it states in my Massey Ferguson manual that warranty is voided if after market back is added....
Dale
   / Top link mount tore off back of differential case #34
After you make the tractor repair, consider selling the 3pt backhoe. And if you really need a backhoe, then purchase a subframe mounted backhoe (BH77) from Kubota or rent one as needed. We all appreciate your candor and documentation of this unhappy event. It's a learning experience for all of us too. Best of success on the repair.
   / Top link mount tore off back of differential case #35
When I see some of the work guys do with these little BHs I am surprised there are not more failures.
I hope your repair goes smoothly. I would not trust a weld up job and I would never use that BH again unless I was sure I broke it doing something I should not have done.
   / Top link mount tore off back of differential case #36
I think thats one of down falls for Kubota, the top link is on the trans housing as appose to others that are on the top 3point lift hosing, which means this is a more costly repair. I thought Kubota did away with that 15 years ago and went with sub frame.
   / Top link mount tore off back of differential case #37
Berlin, I feel your pain. I was worried about my B7800 because I have one implement that is at the maximum weight at 2' from the pins, 1300lbs. The problem is that the weight is 5' from the pins and I was worried about the back of the case. I added 2 bars at the top and welded them to the pick up point and installed 2 bolts into a crossmember (Fig 1 & 2). I then welded a bottom bar and tied it to the 2 bolts at the bottom (Fig 3).
Sorry for your problem.
   / Top link mount tore off back of differential case #38
Kubota did go all sub frame for their BH years ago, thats a Woodmaxx aftermarket BH.
When Kubota did offer a factory 3pt BH if was very limited in capacity for the size tractor and required a reinforcing bracket for the top link mount on the tractor.
   / Top link mount tore off back of differential case #39
Wondering if anyone has experienced (prefer first hand; happened to your tractor) a top link mount being torn off the case of your tractor (any model or make).
I have a 2016 Kubota L3901 with approximately 84 hours and a 3 point (formerly) mounted WoodMaxx 7600 backhoe attached.
I am now aware that some recommend against mounting backhoes with 3 point hitches.
Thanks for any feedback and replies.
View attachment 671562View attachment 671560
Did this happen while trying to pull something out? The BH doesn't even looked used.
Did you accidently try to lift the 3pt with the BH attached?
   / Top link mount tore off back of differential case #40
It’s granular because it was literally ripped in half. Tension failure causes granular looking characteristics.
These 3 point hoes should never be put on tractors. I don’t understand why this L3901 had a 3 point hoe on it when Kubota offers a very nice subframe mounted backhoe. BH77.
My condolences to the OP.
Year: 2019 Make: Jeep Model: Grand Cherokee Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Pla... (A59231)
Year: 2019 Make...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
1996 Timpte 46ft Hopper (A56438)
1996 Timpte 46ft...
Adams Tender / Magnolia Trailer (A56438)
Adams Tender /...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A60429)
2024 CATERPILLAR...
